Newton's Laws and an electron of mass
An electron with a mass of 9.11 x 10^-31 kg accelerates from 4.00 x 10^5 m/s to 6.00 x 10^5 m/s over a distance of 3.00 cm, indicating constant acceleration. Using kinematic equations, the acceleration is calculated to be approximately 66.67 m/s². Applying Newton's second law (F=ma), the force exerted on the electron is determined to be about 6.07 x 10^-24 N. The discussion also touches on the ratio of this force to the electron's weight, which is neglected in the calculations. This analysis provides insight into the dynamics of electron motion under constant acceleration.
nlb149
1. An electron of mass 9.11 x 10^-31 kg has an initial speed of 4.00 x 10^5 m/s. It travels in a straight line, and its speed increases to 6.00 x 10^5 m/s in a distance of 3.00 cm.
(a) Assuming its acceleration is constant, determine the force exerted on the electron.
N (in the direction of motion)
(b) What is the ratio of this force to the weight of the electron, which we neglected?
2. F=ma
Use one of the kinematics equations to determine the accelartion
You have initial velocity, final velocity and distance.
What you know is this, in 0.03 meters of travel you achieved an additional velocity of 2 x10^5 m/s. You also know that s=0.5*a*t^2 thus 0.03 = 0.5*s*t^2 (first equation).
Next you know that v=at and that the increase of velocity was 2x10^5, thus the time could be found by using 2x10^5 = a*t (second equation)
You have two equations with two unkowns, solve for "a" and "t" then use F=ma to get the Force in Newtons. Acceleration will be about 66.67m/s^2 and F about 6.07X10^-24.
Hope this helps.
