Newtons Laws-Force with respect to time
  • Thread starter Thread starter mikee
    Newtons Time
An electron between two charged plates experiences a constant force of 3.0 x 10^-18 N, resulting in horizontal acceleration while moving vertically at 2.0 x 10^6 m/s. The acceleration is calculated using F=ma, yielding a value that allows for further calculations of time and horizontal velocity. The motion consists of uniform vertical motion and accelerated horizontal motion, with no acceleration in the vertical direction. The height of the plates is 1 cm, which is crucial for determining how long the electron remains within the region. The discussion emphasizes the need to separate the components of motion and correctly interpret the forces acting on the electron.
mikee
An electron is oriented between two charged plates (oriented vertically). The electron experiences a constant force perpendicular to the plates. It has a mass of 9.0 x 10^-31 kg, is moving vertically with a velocity of 2.0 x 10^6m/s and enters the region between the two plates. The region has a height of 1cm and while in it the electron experiences a force of 3.0 x 10^-18N. How long does the electron stay in the region, and what is the horizontal component of velocity as soon as the electron passes through the region
Ok here's how i started it, i figured out the acceleration of the particle by F= ma , a= 3.0 x 10^-18/9.0 x 10^-31 and therefore now that i have the acceleration and the x which = 0.001m i can use those to figure out the time and the velocity, so i figured out the velocity by using the equation Vo^2 + 2(a)(d)= V^2
and i used 2.6 x 10^6 for Vo^2 and solved for V and once i found that i used V to solve for the time and i used V= a(t) + Vo is this method correct or am i totally off, would i have to incorporate gravity into it, and also since it says the force is perpendicular to the plates would i have to take the force in the x direction instead of the y direction like i did and if so is it going left or right, those are some details i just wasnt to sure on, if anyone could help thanks alot
The electron is moving upward initially (let's call this y direction).
The acceleration is horizontal (x direction).
1 cm is the height of the plates. There is no acceleration along this direction.
The motion has two components:
- uniform motion along y, with given speed
- accelerated motion along x, with zero initial velocity
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
