Can You Help Me Understand Free-Body Diagrams and Forces in These Block Systems?
  • Thread starter Thread starter emc92
    Laws
The discussion focuses on understanding free-body diagrams for two block systems, specifically systems A and B. Participants emphasize the importance of recognizing the forces acting on the blocks, including weight, normal force, and friction. Clarifications are made regarding how to represent the weight of multiple blocks and the direction of forces, with the consensus that friction opposes motion. The net forces and acceleration for the systems are discussed, confirming that they move together and share the same acceleration. Overall, the conversation aims to clarify the foundational concepts of free-body diagrams and their application in analyzing forces in block systems.
emc92
Free body diagrams for system A that consists of two blocks and for system B with one block:
http://i7.photobucket.com/albums/y260/filipina4eva92/1329082077750.jpg
acceleration and net force from the systems:
http://i7.photobucket.com/albums/y260/filipina4eva92/Unknown.jpg
frictional force:
http://i7.photobucket.com/albums/y260/filipina4eva92/Unknown2.jpgI'm having a hard time understanding how a free-body diagram works. I know that each of the diagrams for the two systems have to have weight, normal force, and friction acting on it, but I don't completely understand the concept behind them. And I don't even know where to begin with the other two parts of the question. Please help! I'm more than willing to understand all of this. Thank you!
First of all you do have to understand what weight, normal force, and friction is to be able to draw the resultant diagram...
1. Weight - what is it's components and in what direction does it act?
2. Normal force - what is it and what direction does it act in (what force does it balance out)
3. Friction - what is it and what direction should it act in (hint: in aerodynamics its called drag)
welcome to pf!
hhi emc92! welcome to pf! :wink:
emc92 said:
I'm having a hard time understanding how a free-body diagram works. … I don't completely understand the concept behind them.
a free-body diagram doesn't really prove anything, it's just a way of making everything clear, so that you don't leave anything out
also, if you're giving the forces names (letters), you can just write them on the diagram, which is a lot clearer than explaining it in prose! :wink:
b. is dead easy
c., use F = ma
d., you'll need to do some calculations :wink:
show us what you get :smile:
@ shyguy79:
1) i know that weight consists of mass and gravity and it's a downward force. for system A, however, since there are two blocks, are there going to be 2 weight vectors on the diagram?
2) normal force is the force perpendicular to the surface of the table, and it's an upward force. it cancels out the force of gravity acting upon the table?
3) friction is opposite the direction of motion of the object. so in this case, friction is acting to the right of the blocks.
at the moment, i only have 3 forces acting on system B - the weight, normal force and friction. is this all for that system?
also, is there a force from system B acting on system A?
@ tinytim
for part b) is the acceleration for all systems the same?
emc92 said:
@ tinytim
they all move together, so yes! :smile:
(sometimes, questions are that easy! :biggrin:)
emc92 said:
@ shyguy79:
1) How would you consider the 'weight' of two blocks - if the mass of each block (and there are two of them) is m and gravity is g then perhaps the weight is ____?
2) Yep... if the surface does not yield under the weight (W = Normal Force)
3) Yep... so F(push) > F(friction) to move the system
Remember friction only exists to opposes the motion so will only be present when there is a pushing force so in essence you've got to remember to pushing force if you're labelling the friction - so you have 4 elements! Like tiny-tim says it is sometimes that easy :-)
@ shyguy 79
so the weight is twice as much for system A. but it's acceptable to only have one vector for the two blocks? also, for system A, is the force opposing friction the force from the hand or from system B? since the hand isn't directly applying the force?
@ tiny tim
i'm still not sure how to begin in parts c and d... =/
for part c, is the net force on system B the same as that on system A? and it's twice as much for system C?
(just got up :zzz: …)
have you misread the diagram?
A is two blocks, B is one block, C is all three blocks :wink:
Lol.. Same here! :zzz:
One vector for two blocks? Why not? When you stand on a scales you get the combined weight of you and your clothes...
From the hand or system B? It's kinda irrelevant it is still a pushing force in the -x direction (left)
I think you should now sit down and use what info you've got and sketch out a rough sketch and see if you can understand what's going on - maybe even put it on here for us to see
