Newton's second condition of equilibrium
To determine the force required to start rolling a 300kg stone wheel over a curb, the weight of the wheel is calculated to be 2940N. The pivot point is at the corner of the step, with an angle of 16.7 degrees formed between the wheel's contact point and the pivot. The normal reaction force, which acts away from the contact point, is crucial for moving the wheel up the step and depends on the applied force. The diameter of the wheel is 1m, and the step height is 0.15m, confirming the derived angle. Accurate calculations of the normal force components are essential for solving the problem.
aud11888
here's the question as written:
A person is attempting to pull a large stone wheel up a step. The wheel has a mass of 300kg. Assuming the force the person applies is horizontal and at the certer of gravity, what imust the force be to start the wheel rolling over the curb?
alright, so i found the weight of the wheel, 2940N, the pivot poing is going to be at the corner of the step, and the angle created between where the wheel hits the ground and the pivot point to be 16.7degrees. i have no clue as to what direction to go in next, can anyone help?
Is the 16.7 deg angle given, because, as you wrote it there's no way to find that angle..
However, a normal reaction force directed away from the point of contact will be the force responsible for moving the wheel up the step, and the normal force is dependant on the force of the person. Break that normal force vector into components.
the angles not given but i derrived it
the diameter of the wheel is 1m and the height of the step is .15m
so using the radius of the wheel, the heigt of the step and the defination of the tangent function i got 16.7degrees
Well you implied that you gave us all the information given. That is the correct angle though.
sorry, it was in the picture and i forgot to type it in
12K
15K
