Newton's Second Law Particle Problem
A particle of mass m is subjected to a force described by F(x) = -k*x^-2, leading to a problem of determining the time it takes to reach the origin when released from rest at x = d. The initial approach involves equating Newton's second law with the force equation, resulting in a velocity expression after integration. However, the user struggles to derive the position as a function of time, expressing uncertainty about the next steps. Another participant suggests using kinematic equations while clarifying that they account for the position-dependent nature of acceleration. The discussion emphasizes the need for careful integration to solve for time, despite concerns about the applicability of kinematic equations in this context.
skyrolla
4. A particle of mass m is experiences a Force that attracts the particle following
F(x) = -k*x^-2
(an inverse square relationship) where x is the distance from an origin at x = 0 and k is a
positive constant. If the particle is released from rest at x = d, how long does it take to reach the origin?
F = ma = m(dv/dt)
Equating Newton's second and the Force equations yields -k*x^-2 = m(dv/dx)(v).
After seperating the variables and integrating once, I got V = sqrt(2k/m)*sqrt((1/x)-(1/d)).
My boundary condition was that at x = d, v =0 for the integration. Setting V = dx/dt and trying to solve for x(t) is unfathomable, so I'm not sure how to continue here, or if I have been taking the wrong approach. I've double checked my math as well, so I don't believe the error is there, but I could always be wrong.
Thanks
Let the velocity of the particle be v when it passes the origin.
The kinematic equation becomes
v = vo + at. But a = -k/m*1/x^2 and vo = 0
So
dx/dt = -k/m*1/x^2 or
x^2*dx = -k/m*t*dt
Find integration between the limits x = d to x = 0 and find t.
Hi skyrolla! :smile:
(have a square-root: √ and an integral: ∫ and try using the X2 tag just above the Reply box :wink:)
If you need to solve ∫ √x/(√x - a) dx, just make the obvious substitution. :wink:
I thought that kinematic equation was only applicable to a constant force, not a position-dependent varying one?
In the kinematic equation we have taken into account the position dependence of the acceleration. And we have taken the integration to find t. So it must work.
