Night Vision Goggles: Explained + Density Effects
  • Thread starter Thread starter Great Smoky
    Vision
Night vision goggles operate by detecting infrared radiation emitted by objects based on their temperature, not their density. The brightness of an object, such as oil on the floor, in night vision depends on its heat rather than its density; hotter objects appear brighter. Night vision technology captures existing infrared radiation and converts it into a visible image, allowing users to see in low-light conditions. The challenge in infrared imaging lies in minimizing the interference from the camera's own heat. Black lights function differently, primarily emitting ultraviolet light rather than detecting infrared radiation.
Great Smoky
Can somebody explain how night vision and/or a black light work? I know it does something where it enhances dark colors to an infrared light spectrum. Would the same concept work for object or fluid density? For example, if I was wearing this night vision goggles and see oil on the floor, will it be brighter when it is more dense versus when it is less dense, etc.?
No, night vision googles see radiated infrared light, which is dependent on the object's temperature, not its density. If the oil on the floor was hot, then it will be brighter. Everything literally glows infrared light just like a heated toaster element glows red (it's called black body radiation). The hotter an object, the more infrared light it gives off. Our eyes are tuned to see visible sunlight reflecting off objects, which obviously fails is in the dark off night. But night-goggles see the infrared radiation that is emitted by object naturally. This is useful because warm-blooded animals and machines that have been running (such as trucks) are much hotter than the environment and therefore are very bright in an infrared image. The important point is that standard infrared cameras (such as in night goggles) don't do anything special. The infrared radiation coming from the landscape already exists where there is a camera or not. The camera just forms the radiation into an image through the use of a lens, then records the image, and then re-displays it on a screen that emits visible light s0 a human can see it. The hard part of actually getting an infrared camera to work is the fact that the camera parts themselves have a temperature and are glowing infrared radiation, which can swamp out the actual signal.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
Thread 'Recovering Hamilton's Equations from Poisson brackets'
The issue : Let me start by copying and pasting the relevant passage from the text, thanks to modern day methods of computing. The trouble is, in equation (4.79), it completely ignores the partial derivative of ##q_i## with respect to time, i.e. it puts ##\partial q_i/\partial t=0##. But ##q_i## is a dynamical variable of ##t##, or ##q_i(t)##. In the derivation of Hamilton's equations from the Hamiltonian, viz. ##H = p_i \dot q_i-L##, nowhere did we assume that ##\partial q_i/\partial...
