No of blade sets in reaction turbines
Multiple sets of blades in reaction turbines are essential for efficiently extracting energy from gas pressure across stages. Using just one set of wider blades may lead to suboptimal energy extraction and potential choking conditions due to reduced effective area. The initial turbine design focuses on stage parameters and blade/gas angles before determining the optimal blade shape and count. This iterative design process ensures that the turbine operates effectively under varying conditions. Ultimately, the number of blade sets is crucial for maximizing performance and efficiency in reaction turbines.
chhitiz
why do we need to have many sets of blades to utilize the gas pressure in reaction turbines properly? why not have just a set of comparatively wider blades?
I assume by sets you're talking about stages. When it comes to stages, it all comes down to how much energy we can efficiently extract per stage. If we can get it all, then we'll just have one vane and one blade.
The preliminary turbine design is done without knowledge of blade shape or count. After the stage parameters and blade/gas angles are calculated, then we go back and try to find a shape and geometry.
Note that depending on your definition of "width" you could be decreasing the effective area through the turbine and reach a possibly unwanted choked condition.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
