Non-calc problem taken out from Spivak's Calculus, I reach a dead end
  • Thread starter Thread starter Hivoyer
    Calculus
The discussion revolves around a problem from Spivak's Calculus that requires proving two statements involving inequalities related to y and y_0. The first part was successfully demonstrated using the reverse triangle inequality, confirming that y is greater than 0. However, the second part, which involves proving that |\frac{1}{y} - \frac{1}{y_0}| < \epsilon, remains unresolved, with participants suggesting further exploration of the transformed inequality |\frac{y_0 - y}{yy_0}|. The conversation highlights the importance of distinguishing cases based on the sign of y_0. Overall, the thread seeks assistance in completing the proof for the second part of the problem.
Hivoyer
The problem states that:
y_0 \neq 0
|y - y_0| &lt; \frac{|y_0|}{2}
|y - y_0| &lt; \frac{\epsilon|y_0|^2}{2}
And I am supposed to use these to prove that:
y \neq 0
|\frac{1}{y} - \frac{1}{y_0}| &lt; \epsilon
|a| - |b| \leq |a - b|
(Reverse Triangle Inequality - my professor hinted me to use it)
Ok proving the first part was easy, I simply used the reverse triangle inequality like this:
1.I change |y - y_0| to |y_0 - y|
2.I use the inequality: |y_0 - y| \geq |y_0| - |y| &lt; \frac{|y_0|}{2} =&gt; -|y| &lt; \frac{|y_0|}{2} - |y_0| =&gt; -|y| &lt; -\frac{|y_0|}{2} =&gt; |y| &gt; \frac{|y_0|}{2} and since we know y_0 is greater than 0, it's square and it's fractions are also greater than 0, so this means y is greater than 0.
Now for part 2 I played around with |\frac{1}{y} - \frac{1}{y_0}| and even after transforming it by completing the fraction addition: |\frac{y_0 - y}{yy_0}| I couldn't figure out how to proceed.Could someone help for this second part?
y_0 \neq 0
y \neq 0
For ##v > 0## the inequality ##|u| < v## is the same as ##-v < u < v##. Now just consider the two cases ##y_0 \geq 0## and ##y_0 < 0##.
I thought y_o could not be equal to 0.You mean y_0 &gt; 0 instead of y_0 \geq 0 right?
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
