What is the Electric Field and Potential of a Non-Uniformly Charged Sphere?
The discussion focuses on calculating the electric field and potential of a non-uniformly charged sphere with a specific charge density. The total charge inside the sphere is derived using integration, leading to the formula Q_enc = (πρ_0/R)r^4 for a radius r within the sphere. For the electric field, the approach differs for points inside and outside the sphere, with the electric field inside expressed as E = (1/4πr^2)(Q_enc/ε_0) and outside using the total charge. The potential difference between the center and a distance r from the center requires separate integrations for r<R and r>R, with the zero reference potential typically set at infinity. The discussion highlights the importance of correctly determining integration limits based on the region of interest.
joemama69
A non-uniformly charged sphere of radius R has a charge density p = p_o(r/R) where p_o is constant and r is the distrance from the center of the spere.
a) find the total charge inside the sphere
b) find the electric field everywhere (inside & outside sphere)
c) find the electric potential difference between teh center of the sphere and a distance r away from the center for both r<R and r>R.
d)Graph the potential as afunction of r
a) Find the total charge in sphere.
p = dQ/dV
Q = integral p dV where dV = 4(pi)R^2dR and it is integrated from 0 to R
Q = integral from 0 to R p_o*(r/R)*4*pi*(R^2)*dR = 2*pi*p_o*r*(R^2)
b) Find electric Field inside & out of sphere
Outisde r>R
Q = 2*pi*p_o*r*(R^2)
\ointEdA = Q_encl / E_o = E(4*pi*(R^2)) = (2*pi*p_o*r*(R^2))/E_o
E = (p_o*r)/2E_o
Inside... r<R
If the rest is correct, can i get a hint on finding the inside as to the outside. this confuses me. it seems the only difference is r<R, but how would that effect the equation.
p = dQ/dV
Outisde r>R
E = (p_o*r)/2E_o
Inside... r<R
dQ = \rho dv = (\frac{\rho_0}{R})r 4\pi r^2 dr
So your integral for (a) is wrong because your dv is wrong. To find the E field inside the sphere draw your Gaussian surface at some arbitrary r inside the sphere. What is Q_{enc}? You know that dQ = \rho dv but what are your limits now?
ok so for part A i integrated and got Q = (4\pipor4)/R and wouldn't that be the same as Qencl because it was the charge in the sphere
Einside = (1/4\pir2)(Qencl/Eo)
what differes when i find it outside
Q_{total} = \frac{4\pi\rho_0}{R}\int_{0}^{R}r^3dr = <br /> \frac{4\pi\rho_0}{R}\frac{R^4}{4} = \pi\rho_0R^3
To find charge inside all you do is change your limits from 0 -> R to 0 -> r where r is an arbitrary radius inside the sphere.
p.s learn latex it's not that hard https://www.physicsforums.com/showthread.php?t=8997.
So if you want the E field outside the sphere, Q_{enc} = Q_{total} since the whole sphere is enclosed with your Gaussian surface.
ok so for part a i wanted the total charge inside sphere which would be Qenc.. correct?
Part A)
Qencl = \pipor4/R
Then for part B i need the Electric field inside and outside
Inside..
E(4\pir2) = Qencl/Eo
and then outside i would solve for Qtotal as you did earlier and use that instead of Qencl in the same equation for the inside
why does my pi always end up like an exponent
Part A)
Qencl = \pipor4/R
Inside..
and then outside i would solve for Qtotal as you did earlier and use that instead of Qencl in the same equation for the insidewhy does my pi always end up like an exponent
Use latex and that link I gave you, it is simple.
(a) Your answer is wrong (I showed you the answer in a previous post) but you are right that Q_{enc}(r) = \frac{\pi\rho_0}{R}r^4 --> This equation is the enclosed charge as a function of your radius with r between 0 and R. It is asking for the total charge of the sphere though. So what is the total enclosed charge if the whole sphere is included? It is just that equation but with r = R.
(b) For inside the sphere: Looks good so far and you know what Q_{enc} is :
Q_{enc}(r) = \frac{\pi\rho_0}{R}r^4.
For outside the sphere: You know what Q_{enc} = Q_{total} or in otherwords your answer from (a).
ok sorr i was confused.. i thought that the charge inside would not include the total sphere
ok now i need to find the potential difference for r<R and r>R
Im confused on the integration limits
r<R do i integrate from 0 to R
r>R i integrate from R to r
It asks for the potential difference FROM THE CENTER OF THE SPHERE and a distance r away from the center
r<R is that a distance r from the center?
r>R is that from the center of the sphere?
the exact wording is
Find the electric potential difference between the center of the sphere and a distance r away fr the center for both r<R and r>R. Be sure t indicate where you have chsen yur zero reference potential.
the example in the book finds the potential for r>R and they integrate from ra to rb, setting rb = infinity
there is not really an exaple for r<R so I am lost
is there a rule for doing this, the book is not clear
Well if you are setting your zero potential to be at r = infinity then for r>R you would do the same integration. For r<R you still have to integrate from r = infinity but to a point r inside the sphere. This requires two different integrals because there are two different E fields (one for r>R and one for r<R).
