Nonnegative Integer Solutions for a+2b+4c=10^30 - Homework Help and Explanation
  • Thread starter Thread starter saubbie
saubbie
I need to find the number of nonnegative integer solutions to the equation a+2b+4c=10^30
I was thinking of trying to find perhaps some sort of a multinomial generating function, but am not sure how that will help me. Any suggestions? Thanks.
Here are my thoughts:
You can find the total number of solutions by incrementally varying parameters. Since for any solution c will be the least likely to be an integer if you choose arbitrary a and b, varying c and trying to peg possible a's and b's would be the wisest way to proceed. For example:
If c=50, a+2b = 10^30-200. Because once again b is least likely to be an integer if we choose arbitrary a subject to a+2b=10^30-200, b would be the best to vary. Anywhere from b=(10^30-200)/2 to b=0 will have a corresponding a, so there are (10^30-200)/2+1 different solutions for the case c=50. Can you see how this result might generalize to all c?
So for all c, there would be (10^30-4c)/2+1 corresponding to every possible c value, but that would give an infinite number of solutions wouldn't it?
If 10^30-4c < 0, do you have any solutions for non-negative b and a? My approach is simply iteratively inspecting the sum and assuming a varying "chunk" of 10^30 is made up of 4c. The answer is definitely finite.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
