Normal modes of a system of springs
The discussion centers on the equation of motion for a system of four identical springs supporting a pallet plate, questioning the inclusion of gravity in the equation. One participant suggests that the correct form should include gravity, while another points out that the reference point for z affects the equation's formulation. The distinction between zero spring tension and equilibrium position is emphasized as crucial for determining the appropriate equation. Additionally, there is a query about using LaTeX for formatting equations, with guidance provided for inline usage. The conversation highlights the importance of context in deriving the correct motion equations for spring systems.
TheGreatEscapegoat
I'm looking at what should be just a simple spring system where four identical springs are holding up a square, load-bearing pallet plate in a warehouse. Now, someone says the equation of motion for the vertical normal mode of vibration is simply d2z/dt2 = -4(k/m)z.
Right away however, I see no gravity in this equation, I think it should be d2z/dt2 = -4(k/m)z + g. Which one is right?
Also where is the LaTex editor here?
It depends on where you want z=0 to be. At the point of zero spring tension? You need your equation. At the point of equilibrium? You need the former equation.
Just put it in double $ or double # (inline).
##\int x^2 dx#[/color]# -> ##\int x^2 dx##
Alright good to know, thank you.
  • · Replies 76 ·
17K
