Normal probability density function
Master J
A production line is producing cans of soda where the volume
of soda in each can produced can be thought of as (approximately) obeying a normal distribution
with mean 500ml and standard deviation 0.5ml. What percentage of the cans will have more than
499ml in them?
Now at my level, the functions to use were simple given to us. The normal probability density function and the standard density function. However, I don't quite understand the idea of P(>499) = 1 - P(<499) = 1 - F(499).
Could anyone explain why that is?
Thanks
I'm not 100% sure of your question, so if this doesn't answer it try again.
If F is a cumulative distribution function (normal or any other) for a continuous random variable, then for any number x, this is true:
<br /> F(x) = \Pr(X \le x )<br />
This means that whenever you need a probability that is of the form \Pr(X &gt; x), you need to rewrite this in terms of the complement inequality:
<br /> \Pr(X &gt; x) = 1 - \Pr(X \le x)<br />
This is what happens in your problem, with x = 499. Is this the type of thing you want?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
