How do I properly normalize a wave function with given real functions?
To normalize the function ψ = N(ψ1 - (1/√6)ψ2 + (√3/√6)ψ3), the normalization condition requires that the integral of ψ squared over all space equals 1. The user is unsure about the integration limits since no specific x values are provided, but the integral should be evaluated from -∞ to ∞. It is important to substitute the entire expression for ψ into the integral and consider the orthogonality and normalization of the functions ψ1, ψ2, and ψ3. Clarification on the integration method is needed, as the user initially performed an indefinite integral instead of a definite one. Understanding the normalization condition and properly applying it to the given function is crucial for solving the problem.
ReidMerrill
"assume that the three real functions ψ1,ψ2, and ψ3 are normalized and orthogonal. Normalize the following function"
ψ1 - ψ21/(sqrt2) + ψ3sqrt(3)/sqrt(6)
This is for a physical chemistry class. I haven't seen an example like this. All that is in our textbook is that integral[ /ψ/2dT] needs to equal 1 which is accomplished by adjusting N so N2 Integral[ /ψ/2dx] =1
Is this correct? What range do I integrate it over? no x values are given.Any help will be greatly appreciated!
[/B]
[/b]
Is what correct? You haven't shown any work.
The readability of your post would improve if you use LaTeX. Here's a primer: https://www.physicsforums.com/help/latexhelp/.
I don't know why all my subscripts disappeared.
ψ1 - ψ2 1/(sqrt6) + ψ3 sqrt(3)/sqrt(6)
In the book it says that to normalize a function you need to adjust N so that
N2 Integral [/ψ/2 dx] =1
I don't know how I'd apply that to this question
In this problem, you have ##\psi(x) = N\left(\psi_1 - \frac{1}{\sqrt{6}} \psi_2 + \frac{\sqrt{3}}{\sqrt{6}}\psi_3\right)##. (Are you sure about that state? It's written a bit strangely, i.e., ##\sqrt{3}/\sqrt{6} = 1/\sqrt{2}##.)
That's how it's written in the book.
Since x isn't in the function
That's just how it's written. So when I integrate that with respect to x i get N(ψ1 - ψ2 1/(sqrt6) + ψ3 sqrt(3)/sqrt(6))x +C
Did I integrate that correctly? And if so what do I do from here?
Remember that ##\psi_1##, ##\psi_2##, and ##\psi_3## are functions of ##x##. You said the normalization condition is
$$\int_{-\infty}^\infty \psi^2\,dx = 1.$$ You want to substitute the expression you're given for ##\psi## and evaluate the integral.
Think about what it means when you're told that the ##\psi_i##'s are normalized and orthogonal to each other.
Ohhh! I did it as an indefinite integral. So, just to clarify, I need to plug in the whole original equation into the integral?
