MHB How Does One Solve the Integral of Logarithmic Functions Over a Unit Interval?
  • Thread starter Thread starter alyafey22
    Integral Logarithm
The integral of the logarithmic functions over a unit interval, specifically $$\int^1_0 \frac{\log(1+x)\log(1-x)}{x}\,dx$$, is discussed with a focus on the correct method for multiplying series. The error identified in evinda's solution pertains to using the pointwise product instead of the Cauchy product for absolutely convergent power series. This distinction is crucial for accurately solving the integral. The conversation highlights the importance of proper series multiplication techniques in calculus. Understanding these methods is essential for resolving similar logarithmic integrals effectively.
alyafey22
MHB
logarithm integral # (2)
Solve the following
$$\int^1_0 \frac{\log(1+x)\log(1-x)}{x}\,dx$$​
Mathematics news on Phys.org
ZaidAlyafey said:
Solve the following
$$\log (1-x)=-\sum_{n=1}^{\infty} \frac{x^n}{n} \text{ for } |x|<1$$
$$\log (1+x)=\sum_{n=1}^{\infty} (-1)^{n+1} \frac{x^n}{n} \text{ for } |x|<1$$
So:
$$\frac{\log(1-x)\log(1+x)}{x}=\frac{- \sum_{n=1}^{\infty} \frac{x^n}{n} \cdot \sum_{n=1}^{\infty} \frac{(-1)^{n+1} x^n}{n}}{x}=\frac{\sum_{n=1}^{\infty} (-1)^{n+2} \frac{x^{2n}}{n^2}}{x}=\sum_{n=1}^{\infty} (-1)^n \frac{x^{2n-1}}{n^2}$$
Therefore:
$$\int_0^1 \frac{\log(1+x) \log(1-x)}{x} dx=\int_0^1 \sum_{n=1}^{\infty} (-1)^n \frac{x^{2n-1}}{n^2} dx=\sum_{n=1}^{\infty} \frac{(-1)^n}{n^2} \left [ \frac{x^{2n}}{2n}\right ]_0^1=\frac{1}{2} \sum_{n=1}^{\infty} \frac{(-1)^n}{n^3}$$
How did you perform the multiplication of the two series ?
In evinda's solution, there is an error made in multiplying the two series. The product of two absolutely convergent power series is given by the Cauchy product, not pointwise product.
I see..I am sorry! (Tmi)
$$\int^1_0 \frac{\log(1-x)\log(1+x)}{x}\,dx = -\zeta(2)\log(2)+\int^1_0 \frac{\mathrm{Li}_2(x)}{1+x}\,dx $$
$$\int^1_0 \frac{\mathrm{Li}_2(x)}{1+x}\,dx = \int^1_0 \sum_k (-x)^k \mathrm{Li}_2(x) = \sum_{k\geq 1} (-1)^{k-1}\int^1_0 x^{k-1} \mathrm{Li}_2(x) $$
Since
$$\int^1_0 x^{k-1}\mathrm{Li}_2(x)\, dx = \sum_{n\geq 1}\frac{1}{n^2(n+k)} =\frac{1}{k}\left(\zeta(2)-\frac{H_k}{k}\right)$$
We've got
$$\int^1_0 \frac{\mathrm{Li}_2(x)}{1+x}\,dx =\zeta(2)\sum_{k\geq 1} \frac{(-1)^{k-1}}{k}-\sum_{k\geq 1} (-1)^{k-1}\frac{H_k}{k^2} = \frac{1}{24}\left(4 \pi^2 \log(2)-15 \zeta(3)\right)$$
$$\int^1_0 \frac{\log(1-x)\log(1+x)}{x}\,dx = -\zeta(2)\log(2)+\zeta(2)\log(2)- \frac{15}{24} \zeta(3)=\frac{5}{8}\zeta(3)$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
