WJEC GCSE Physics 2 Higher Tier Q5(c)(ii) Help
In summary, the question asks for an explanation of why the velocity of a barium nucleus released with the same kinetic energy as a neutron would only be one twelfth of the neutron's velocity. This is due to the difference in masses between the two particles and can be calculated using the equation KE = (1/2)mv^2 and setting up a proportion between the masses and velocities.
Tomos
Question 5 (c) (ii) from the paper physics 2 higher tier January 2014 by wjec. There is no mark scheme at the moment of the paper and I do not understand the question. The paper is at the bottom of "papers" at http://www.wjec.co.uk/qualifications/qualification-resources.html?pastpaper=true&subject=Physics&level=gcse and the question is " if a barium nucleus is released with the same kinetic energy as a neutron, explain why the size of its velocity would only be one twelfth (1/12) of the velocity of a neutron". Please help!
N/A
Barium has a greater mass than a neutron?
KE in this case is given by ##\frac{1}{2} mv^2## . You're close when you think about the difference in masses. What is their ratio? How does ##m## relate to ##v##? Think about it.
Okay thanks!
With a greater mass and an equivalent kinetic energy, the velocity of the barium nucleus will be much small considering the mass is so much greater than that of the neutron. Ke=(1/2) mv^2 therefore if you set up a proportion you could calculate the velocity of the neutron compared to the barium.
1. What is the format of WJEC GCSE Physics 2 Higher Tier Q5(c)(ii)?
The question format for this section consists of a scenario followed by multiple choice questions related to the scenario.
2. How many marks is WJEC GCSE Physics 2 Higher Tier Q5(c)(ii) worth?
This question is worth 3 marks in total.
3. What topics are covered in WJEC GCSE Physics 2 Higher Tier Q5(c)(ii)?
This question covers topics such as energy transfers, electrical circuits, and energy efficiency.
4. How much time should I spend on WJEC GCSE Physics 2 Higher Tier Q5(c)(ii)?
It is recommended to spend around 10 minutes on this question, as it is one of the longer questions on the exam.
5. How can I prepare for WJEC GCSE Physics 2 Higher Tier Q5(c)(ii)?
To prepare for this question, it is important to review relevant topics, practice with past exam papers, and familiarize yourself with the question format.
10K
  • Beyond the Standard Models
