Nuclear Reactions and Symbol Notation
The discussion focuses on completing a nuclear reaction involving uranium-232. The user successfully identified the mass number (228) and atomic number (90) but struggled with determining the correct symbol for the resulting element. Participants suggest consulting a periodic table to find the symbol corresponding to atomic number 90. The correct symbol for the element with these properties is thorium (Th). The conversation emphasizes the importance of using reliable resources, like a periodic table, for accurate scientific notation.
leah0084
Complete the following nuclear reactions
Enter mass number, atomic number, and then symbol
A) 232 92U--->4 2He + 228 /90 / _______________
4 2He + 228 90U
i got the mass number (228) and atomic number (90), but i could not figure out how to write the symbol.
will anybody please help me?
my guess of symbol was 4 2He + 228 90U but obviously it was wrong
Consult a periodic table to figure out what is the symbol of the element with mass number 228 and atomic number 90.
thank you
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
