Number of Wavelengths Emitted from Excited Atomic Hydrogen Level 4
  • Thread starter Thread starter aurao2003
    Wavelengths
The discussion centers on determining the number of different wavelengths emitted when atomic hydrogen is excited to level 4. The initial calculation suggested 10 wavelengths based on transitions from level 4 to lower energy levels. However, the correct approach indicates that there are only 6 distinct wavelengths, derived from the transitions between levels 4, 3, 2, and 1. The formula n(n-1)/2 is referenced to clarify the calculation method, emphasizing the importance of considering unique transitions rather than counting all possible paths. Ultimately, the conclusion is that six different wavelengths can be emitted from level 4.
aurao2003
hi
i came across this problem on an aqa physics a past question.
How many different wavelengths of electromagnetic radiation can be emitted after
atomic hydrogen is excited to level 4?
i was looking at transitions from level 4 to the ground. i obtained 10 but the answer suggested 6. this was my conclusion;
from level 4 (4 wavengths. this was calculating from 4 to 3, 4 to 2, 4 to 1 etc)
i calculated in this manner for level 3 to the ground, 2 to the ground state etc.
can someone kindly clarify where i am going wrong?
thanks
How did you get 10? Count again?
The formula for it is n(n-1)/2 where 'n' is the energy level from where it is excited.
You can derive it using Combinations.
You have only listed 3 wavelengths, not 4:
4→3
4→2
4→1​
aurao2003 said:
hi
from level 4 (4 wavelengths. this was calculating from 4 to 3, 4 to 2, 4 to 1 etc)
thanks
A hydrogen atom excited to level 4 may transition to the ground state by emitting radiation by any of the following 4 schemes. \displaystyle \lambda_{\,i\,\to 1} is the wavelength emitted as the atom transitions from level i to level j.
\displaystyle \lambda_{\,4\,\to 1}
\displaystyle \lambda_{\,4\,\to 2} followed by \displaystyle \lambda_{\,2\,\to 1}
\displaystyle \lambda_{\,4\,\to 3} followed by \displaystyle \lambda_{\,3\,\to 1}
\displaystyle \lambda_{\,4\,\to 3} followed by \displaystyle \lambda_{\,3\,\to 2} followed by \displaystyle \lambda_{\,2\,\to 1}
\displaystyle \lambda_{\,4\,\to 3} and \displaystyle \lambda_{\,2\,\to 1}, each appear twice in the above. Therefore, there are six different wavelengths which may be emitted.
They are: \displaystyle \lambda_{\,4\,\to 1},\ \lambda_{\,4\,\to 2},\ \lambda_{\,4\,\to 3},\ \lambda_{\,3\,\to 1},\ \lambda_{\,3\,\to 2},\ \lambda_{\,2\,\to 1}
thanks a lot everyone. its clear now!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
