Numerical Computation (Euler method)
helpcometk
Differential equations are important in physics.Consider Solving the differential equation dy/dx = Σ(from i to N) (ai) (x^i)
Using Euler ,Midpoint ,4th order Runge -Kutta methods.For each of these methods what is the largest value of N that would lead to an exact solution ?
Well, what are you having difficulty with?
I simply do not have an idea what i have to do
I don't understand anything. What are the conditions for exact solution ??
I don't know anything.
To solve this, I first used the units to work out that a= m* a/m, i.e. t=z/λ. This would allow you to determine the time duration within an interval section by section and then add this to the previous ones to obtain the age of the respective layer. However, this would require a constant thickness per year for each interval. However, since this is most likely not the case, my next consideration was that the age must be the integral of a 1/λ(z) function, which I cannot model.
