Numerical integration - Techniques to remove singularities
4 replies · 6K views
franciobr
Hello everyone!
I am trying to understand why the following function does not provide problems to being computed numerically:
∫dx1/(sin(abs(x)^(1/2))) from x=-1 to x=2.
Clearly there is a singularity for x=0 but why does taking the absolute value of x and then taking its square root solve the problem?
I searched for quite a while on the internet and on numerical integration books and was surprised that I couldn't find the answer for that. Apparentlly there is a lack of documentation on singularity removal techniques on the web or I am not searching with the right keywords. Any introductory documentation on the subject is welcome!
For the record I am using MATLAB built-in functions such as quadtx() or integral() to solve it but I that's not the point since it turns out even the most simple simpson rule algorithm can deal with that integral.
Just because you get a certain number out of a numerical routine does not mean it is accurate. Convergence for a particular definite integral containing a singularity within the limits of integration must be shown using other analysis methods before judging whether the resulting evaluation has any meaning.
Yes. The result is accurate since if you exclude the singularity by simply integrating from -1 to 0 and then from 0 to 2 and sum them up the answer is exactly the same. I do not know how to analytically solve this integral and, well, that's the whole point of numerical integration.
I dind't mention that if you try to take the integral without taking the absolute value or the square root you get no answer and there is no convergence of the method. I am interested on why quadrature methods of integration converges on these cases. I am not interested on that particular integral, if you do the same with 1/x kinds of functions and integrate it going through its singularity on 0 you get convergence for the same methods of integration and they agree with analytical results. There is a reason why taking taking a square root and the absolute value of the denominator the numerical methods converges.
The absolute value application seems logical since you don't want a imaginary number coming out of the square root. But the convergence of the method is what astonishes me. I would like to know why there is the convergence and also if anyone has a good source for these techniques of excluding singularities for numerical integration.
It's fairly easy to see that the integral is convergent. Expand the function as a power series and you get $$\frac{1}{|x|^{1/2}} \frac {1}{1 - |x|/3! + |x|^2/5! - \cdots}$$
So close to ##x = 0## the function is similar to ##|x|^{-1/2}## which can be integrated everywhere.
If you want to remove the singularity before you do the numerical integration, one way is to write the function as ##f(x) = s(x) + g(x)## where the ##s(x)## contains the singular part and can be integrated explicitly.
Then integrate ##s(x)## analytically and ##g(x)## numerically.
For this example you could take ##s(x) = |x|^{-1/2}## and ##g(x) = f(x) - s(x)## (where ##f(x)## is the function the OP wants to integrate).
You know that ##g(0) = 0## and ##g(x)## is well behaved near ##x = 0##, so any numerical integration method should converge quickly.
