Object moving in equilateral triangle - magnitude of acceleration
An object moves with a constant speed of 22.3 m/s around an equilateral triangle, completing the path in 12.69 seconds. The average acceleration vector's magnitude is calculated using vector components and relevant equations. The solution involves breaking down the motion into x and y components. The final calculated average acceleration is 3.04 m/s². This demonstrates the relationship between constant speed and changing direction in circular motion.
physos
An object moves around a equilateral triangle with a constant speed (magnitude of velocity is constant) of 22.3 m/s. If it moves from the starting to ending point (as shown below) in a time of 12.69 seconds, what is the magnitude of the average acceleration vector in m/s2?
V\DeltaV= (rFx-rix/delta(t)) - (rfy-riy\delta (t))
Break the vector into x and y components then use the equation:
(delta)y=v0t-(1/2)gt^2
Thanks! i figured out the answer.. its 3.04
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
