Obtain the equivalent resistance at the terminals a-b
The discussion revolves around determining the equivalent resistance at terminals a-b in a circuit involving multiple resistors. Participants explore various methods to analyze the circuit, including series and parallel combinations, voltage dividers, and symmetry considerations.
  • Homework-related
  • One participant attempts to identify series and parallel resistors but expresses uncertainty about the configuration and the resulting equivalent resistance.
  • Another participant hints at the importance of current direction through the 10 Ω resistor, suggesting a need for clarity on current flow.
  • A participant questions the current flow direction, considering the resistance values of the surrounding resistors.
  • Hints about symmetry are provided, with one participant suggesting that the current on opposite sides of the circuit should be identical.
  • Another participant discusses voltage dividers and asks about voltage drops across resistors in series, probing the implications of resistor configurations on voltage distribution.
  • A participant shares that they resolved their confusion by learning about delta-wye conversions, which allowed them to simplify the circuit and find the equivalent resistance.
  • There is a clarification that delta-wye conversions were not necessary for understanding symmetry in the circuit.
Participants express varying levels of understanding regarding the circuit's configuration and the application of symmetry. There is no consensus on the necessity of delta-wye conversions, and some participants remain confused about the implications of symmetry on current flow.
Some participants mention missing knowledge about delta-wye conversions, which may limit their ability to analyze the circuit effectively. The discussion reflects uncertainty regarding the current flow and voltage distribution in the circuit.
FBS
[PLAIN]http://img593.imageshack.us/img593/6015/251a.png
for combining resistors in series: R1 + R2
for combining resistors in parallels: R1R2/(R1 + R2)
I've tried redrawing the circuit many times trying to make it easier to see which are in series and which are in parallel but I cannot arrive at the answer 9.231 ohms. I think? that the 20 ohm resistor in the upper right is in series with the 10 ohm in between the two 20s, but I'm not even sure about that.
Hi FBS! :smile:
Hint: which way is the current flowing thorugh that "horizontal" 10 Ω ? :wink:
I am not so sure. It looks like it could be flowing in both directions. :( Would it be flowing to the right because the 20 ohm resistor "resisted" more of the current than the 10 ohm one did?
Hint2: symmetry. :wink:
I think I feel more confused than ever. I'm not sure how symmetry affects the current unless you mean the current on the opposite side of the circuit should be identical? But they all seem different to me, maybe I'm not understanding some basic principle...
[PLAIN]http://img638.imageshack.us/img638/6015/251a.png
Think about the voltage dividers and the symmetry as tim has suggested.
When you have a voltage across two 10 Ohm resistors, what is the voltage at the midpoint? Like, if you have 2V across two 10 Ohm resistors in series, how much voltage drop is there across each? What if they were 20 Ohm resistors, would the midpoint voltage be any different?
And if you have a voltage across a resistor that is 100 Ohms, would anything be different it you made that 100 Ohm resistor out of two 50 Ohm resistors?
So it turns out I couldn't figure it out because I hadn't learned delta-wye conversions yet. D'oh. I was able to get the right answer by converting the three 10 ohm resistor Y to a triangle of 30 ohms which then let me parallel the two 20 ohm resistors with two 30s and then parallel the remaining two 30s.
[PLAIN]http://img857.imageshack.us/img857/5959/251p.png
Was Delta-Wye what you guys meant by symmetry?
nooo … you didn't need it
no
let's see … now you have the equivalent resistance, can you say how much of the current goes through that "horizontal" 10 Ω resistor, and which way? :wink:
