Obtaining a more accurate calculator?
  • Thread starter Thread starter Michio Cuckoo
    Calculator
Michio Cuckoo
I'm trying to calculate relativistic photon energy shifts, and I have to use e^{\frac{x}{c^{2}}}
However,since I'm dealing with the speed of light, the exponent becomes extremely small and my TI-84 gives me a nonsensical value.
Could anyone recommend a more accurate calculator?
Mathematics news on Phys.org
If \frac{x}{c^{2}} is that small, how inaccurate would it be to approximate the answer as 1+\frac{x}{c^{2}}?
so you think i should use maclaurin's expansion?
Yes, just cut the first two terms. By the Lagrange form of the remainder, we obtain that an upper bound for the error can be given by \displaystyle \frac{x^{k+1}}{(k+1)!c^{2k+2}} in a Taylor polynomial of degree k. Taking k as two (the above case), we obtain that an upper bound of the error is \displaystyle \frac{x^3}{6c^6}, which, as long as x\leq c, is accurate to at least 5 decimal places.
That would be taking the first 3 terms, no? Sure, that should be fine, but the first two terms might be enough. How big is x/c2, and how accurate do you need the answer to be?
my answer would be in the range of 10^-11 eV.
x/c2 has units? Doesn't seem right. What exactly does x represent?
