Ocean liner in bucket full of water
147 replies · 28K views
256bits
- 2,297
dacruick said:I meant force. Show me where your force comes from. Explain how a thin film of water (uncompressed) exerts 10 000 000 lbs worth of force in any scenario.
Roller bearings, ball bearings, journal bearings ride on a thin film of oil nanometeres ( micro-inches ) thick with pressures approaching the MPa range. Consider that your car is supported on a thin film on each wheel nanometers thick, millimetersr so in width and centimeters long.
Scale that up to the size of a ship and a thin layer of fluid can support the weight of a ship,
dacruick
- 1,038
- 1
Borek said:Do you agree amount of water in the third one can be just a bucket?
Unless the weight of the water along the sides of the bucket is equal to the weight of your block, then it will not float. the block will sink to the bottom of your bucket, and push the same volume of water that was sitting under it out of the bucket.
A "thin" film suggests that the water's thickness approaches zero, which means that the water will have negligible weight, and therefore there is no plausible way that the block could be floating.
dacruick
- 1,038
- 1
If you use your logic and approach the limits of the problem you will see a discontinuity. Borek, from your diagram, you could theoretically make the walls of the bucket disappear. Then you would have a block on top of an infinitesimally thin layer of water.
EDIT: And if you have no space between the walls of the bucket and the block, then you have compression. Which is the only method of possibility to this problem.
- 4,345
Let's say the second hull is build from the bottom of the lake, piece by piece.dacruick said:It stops floating when you build the second hull. The second hull will still float, but there will be contact between the second hull and the ship.
When exactly will the ship stop floating? When we put the last piece in place?
dacruick
- 1,038
- 1
If the hull is completely under water then it's existence is trivial is it not?
Why won't you address my question about the origin of the buoyant force that you claim to be there.
Homework Helper
- 4,474
- 923
dacruick said:No matter what scenario it is, there is the weight of the ship. If the weight of the ship is mass * gravity, and the ship is floating (not accelerating), where is this force causing buoyancy coming from?
From the hydrostatic pressure of the liquid.
A boat 92 m long and 6 m wide (I found these numbers online) has an area of the submerged part of about 1800 m^2.
A column of water 10 cm high will exert a force
F= 1000 kg/m^3 * 10m/s^2* 0.1 m *1800 m^2, about 1.8 MN (or 180 tons).
Allowing that the force exerted by the pressure is not everywhere upward, it gives you an order of magnitude estimate of hundreds of tons.
Is not the compression of water that matters. Is not like sitting on a spring.
cmb
- 1,128
- 128
dacruick said:I can't believe that this idea is being proposed without a source of the force to keep the boat afloat.
It wasn't an idea. I was explaining what actaully happens in wet/dry dock.
You seem to be under an illusion that there is a 'pressure' required something like the magnitude of the ship. But if you want to look at it that way, it is the ship's mass all supported on an very large surface area, thus a 'realtviely low pressure' is all that is required. The relative pressure required to 'lift the boat' will match the pressure of however-many-metres of vertical liquid height there is in that small thickness of water.
I suggest you drop the whole idea of 'pressure' and think about 'density'. Once 'afloat' the ships hull below the water line will have exactly the same density as water. Now picture a lump of water floating in that water. Would that body of water sink? See how it is wrong to think it will sink against the water?
Mentor
- 29,213
- 4,643
dacruick said:Why won't you address my question about the origin of the buoyant force that you claim to be there.
You were already told where the buoyant force comes from - it is pressure the water exerts on the ship hull.
And it was also signaled that yes, bucket walls have to survive the pressure as well, yes, bucket walls support the water. But ocean bottom have to survive this pressure as well. There is no difference between both cases. The only difference is amount of water used. Ship doesn't come in contact neither with the sea bottom nor with the bucket walls - it floats in water.
dacruick
- 1,038
- 1
Borek said:You were already told where the buoyant force comes from - it is pressure the water exerts on the ship hull.
Then you have water under immense pressure, don't you? And if the water is under immense pressure then it will always try to flow to lower pressure. And unless you've capped your bucket, it will flow outside, to the low pressure.
Homework Helper
- 4,474
- 923
dacruick said:Then you have water under immense pressure, don't you? And if the water is under immense pressure then it will always try to flow to lower pressure. And unless you've capped your bucket, it will flow outside, to the low pressure.
No, you don't. The pressure required to support a 200 ton boat may be of the order of 1/100 atmosphere. Water compression under this pressure is negligible.
Maybe it will help if you explain where do you think the force comes from when the boat floats in the ocean.
cmb
- 1,128
- 128
You tell us. What's the psi to lift a ship? - name a ship and give us its mass/hull-surface-area?
(I can tell you - it is the same pressure as that of a given draught of water it sits in! Obviously!)
256bits
- 2,297
If the water is under immense pressure, instead of flowing out, it could just as well want to push the ship higher up in the bucket. Both scenarios cannot be correct.would you agree.
dacruick
- 1,038
- 1
I can't possibly be right if this many people oppose me. I must have one really huge assumption in my logic. I understand that the force comes from the walls of the ocean, and I can see how that specifically can be extended to the bucket scenarios.
dacruick
- 1,038
- 1
I just don't see how under the weight of the ship, the water does not get displaced. Borek, in your diagram of the three scenarios, what is stopping the water at the bottom of the bucket from being displaced? Intuition (which is not serving me too well today) tells me that it is the water along the edges. But how can that be possible when the volume of water along the edges is so small?
cmb
- 1,128
- 128
dacruick said:I just don't see how under the weight of the ship, the water does not get displaced. Borek, in your diagram of the three scenarios, what is stopping the water at the bottom of the bucket from being displaced? Intuition (which is not serving me too well today) tells me that it is the water along the edges. But how can that be possible when the volume of water along the edges is so small?
The water in the gap is, at that point, the same density as the ship's hull. Why would the ship's hull sink lower if it is not of a greater density than the water?
Mentor
- 29,213
- 4,643
Pretty simple - pressure is a function of density and height of the column, doesn't matter how thin the column is.
Edit: well, at some point it starts to be too thin, and it doesn't behave as a water any longer, but even if it is just a tenth of a millimeter it is still thick enough.
256bits
- 2,297
In your defense I will say: The plate techtonics guy originally came up against stiff opposition to his theory. The quasi-crystal guy was ridiculed at his discovery and what did he just win - a Nobel prize. :)
jmmccain
- 17
- 2
Here is a simple, quick, and cheap (no aircraft carriers needed) experiment:
Obtain two stackable drinking glasses, like those used at fast food restaurants. Fill one with water. Set the other, empty glass, in the water. The second glass, being empty (and light) will displace a small amount of water and float. Place coins (or other suitably heavy objects) into the empty glass. Once the second glass is half of the way into the first, you can tell it is still floating. Continue adding coins until the glass is almost all of the way down. This represents the ship in a bucket and it is still easy to observe that it is floating. Continue to add coins and the glass would sink - were it not for the experiment's simple design. Remove the second glass. Note the tiny amount of water that remains in the first. Put the second glass back in. Note that it still floats even though no water was spilled this time.
cmb
- 1,128
- 128
Further still, once the 'inner' glass has been balanced with coins that it is just floating off the bottom of the other glass, note whereabouts the water level comes up to. Then, with that glass still with its coin weights, float it in a big sink of water and note whether it floats to the same depth or not.
jmmccain
- 17
- 2
For a real life example of ships in a bucket, see: http://en.wikipedia.org/wiki/Panamax
- 4,345
jmmccain said:For a real life example of ships in a bucket, see: http://en.wikipedia.org/wiki/Panamax
Or here, the entire bucket is even lifted:
http://en.wikipedia.org/wiki/Strépy-Thieu_boat_lift
[URL]http://www.canal-du-centre.be/Education/Ast/Images/stcptran.gif[/URL]
From :http://www.canal-du-centre.be/Education/Ast/En/commentcamarche.html
- 15,622
Arrrrgggghhhh !
Well I really HATE being wrong but the one thing I hate more than being wrong is being wrong and thinking I'm right, so I thank all the folks in this thread who helped me see the error of my ways.
What I REALLY had a hard time getting my head around was that absent any weirdnesses due to an odd shaped object bottom, no only will the object float, you CAN, despite my previous vehement objection, start with a small amount of water and end up with the object floating. You could put the object into the container, displacing most of the water, then remove the object then place it in again (somewhat carefully so it doesn't rub against the walls) and it will float again.
Color me embarrased.
gulfcoastfella
- 1
The basic situation is played out every day on the Mississippi river. Casinos aren't allowed to operate on land, so they build a 'bucket' inland that's slightly larger than the barge the casino sits on, and then they run a tiny channel from the river into the bucket. Legally, the casinos have defended what they've done by saying the barge the casino sits on is floating on the river, even though it's technically sitting on a layer which is fed by the river.
DaveC426913
2025 Award
- 24,698
- 9,103
BTW, it is not the one pound of water holding the boat up.The "force" that supplies the lifting for the boat is the rigidity of the very thick walls containing the water and boat. The walls must be thick enough to withstand the huge sideways pressure that the boat will exert on them (via the 1mm of water).
Think about those nested glasses again. When the inner glass is empty, it will float very high. To get it to sink manually, you have to apply pressure to push it down. This will exert pressure on the walls. Enough pressure and you could break the outer glass.
Anyone ever tried to "drown" a beachball? It is virtually impossible. It requires a lot of downward force. In a contained tank, that force gets transmitted to the walls as the water level rises. The walls must be strong.
The walls of a tank to contain an ocean liner must be strong indeed.
- 4,345
The forum would be useless, if nobody ever learned anything new here. Here is a related question:phinds said:I thank all the folks in this thread who helped me see the error of my ways.
Let's say you have an elevated water way on pillars like the upstream entrance to the ship lift:
http://3.bp.blogspot.com/_N7rE_MLfr...1600/Strépy-Thieu+on+the+Canal+du+Centre.jpg
Does the vertical load on the pillars increase, when a heavy ship passes overhead?
xxChrisxx
- 2,056
- 85
Borek said:The water is all around - in the form of a thin film. What is important is that water exerts pressure on the hull - and it exerts pressure everywhere on the hull surface, just like it would in the case of the boat in the ocean. Yes, in theory it is possible to float an air carrier in a gallon of water.
Archamedes would disagree, or you are using a very odd definition of floating.
Floating is all down to buoyancy (the point that the buoyancy force => the object weight in air). 1 L of freshwater will give 1kgf of upthrust. The upthrust comes from the displacement and there is no appreciable change in pressure of the water. In the case of a 500 ton ship, you must be displace 500000L of water to provide the necessary upthrust.
If water is in thin film it is being used as hydrostatic bearing (which isn't the same as floating), meaning it's simply transferring the load through to an external container due to it being incompressible and the pressure increasing. It also means that the water must be contained to allow an increase in pressure.
In your drawing in a later post, you show a decreasing sized container with the aim of 'proving' that even though you make the container smaller it's still floating. However what you have drawn makes no sense in the 3rd case unless the water is contained somehow. In your drawing the top is shown as being open to air, so the water will not increase in pressure, but flow (in this case over the sides)
They are two different modes of supporting a ship. I would not agree from a technical standpoint that bearing is the same as floating.
(EDIT: I don't know if I'm agreeing with you or not, this thread is pretty hard to follow).
- 4,345
Displacement is simply the volume of the ship below the water surface. The displacement of the same ship in the tight pool is the same as in the ocean.xxChrisxx said:In the case of a 500 ton ship, you must be displace 500000L of water to provide the necessary upthrust.
So where exctly between drawing 2 & 3 does the body stop floating?xxChrisxx said:In your drawing in a later post, you show a decreasing sized container with the aim of 'proving' that even though you make the container smaller it's still floating. However what you have drawn makes no sense in the 3rd case unless the water is contained somehow.
The pressures at the floating body are the same in all 3 pictures. They must counter the weight which is the same as well.xxChrisxx said:In your drawing the top is shown as being open to air, so the water will not increase in pressure,
Undergrad
Whirling a bucket full of water
- Himal kharel
- · Replies 10 ·
- Mechanics
- Replies
- 10
- nouveau_riche
- · Replies 52 ·
- Mechanics
- Replies
- 52
- DaveC426913
- · Replies 13 ·
- Mechanics
- Replies
- 13
High School
A cylinder full of water on a scale
- nargesh
- · Replies 2 ·
- Mechanics
- Replies
- 2
- Gh778
- · Replies 3 ·
- Mechanics
- Replies
- 3
- velvetymoogle
- · Replies 3 ·
- Introductory Physics Homework Help
- Replies
- 3
- SA32
- · Replies 2 ·
- Replies
- 2
- JasonL
- · Replies 2 ·
- Replies
- 2
- cdhotfire
- · Replies 5 ·
- Replies
- 5
- Jimsac
- · Replies 2 ·
- Replies
- 2
