Ok, how should I go about this one?
  • Thread starter Thread starter matt85
To determine the net charge on a 12.00g plastic ball suspended in a uniform electric field of 10^3 N/C at a 30° angle with the vertical, one must analyze the forces acting on the ball. The ball is in equilibrium, indicating that the net force is zero, meaning the electric force and gravitational force are balanced. By identifying the forces and setting up equations for both the x and y components, one can solve for the charge using Coulomb's Law. The equilibrium condition allows for the calculation of the charge based on the known values of the electric field and the weight of the ball. This approach leads to the determination of the net charge on the ball.
matt85
Pendulum
A small 12.00g plastic ball is suspended by a string in a uniform, horizontal electric field with a magnitude of 10^3 N/C. If the ball is in equilibrium when the string makes a 30 ° angle with the vertical, what is the net charge on the ball?
Q = _________ C
I know Coloumb's Law, and I assume I want to implement it here somehow, however I don't know where to begin on setting this one up.
Oh, and here is the visual.
The ball is in equilibrium. What does that tell you?
That there is no force acting on it?
No, that isn't exactly the definition of equilibrium.
Equilibrium is when there is no _net_ force acting on it.
That there's no net force acting on it. Or, in other words: The net force is zero.
Start by identifying all the forces acting on the ball, then set up the equations for equilibrium. (Analyze the x and y components separately.)
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
