Fixing Old Dishwasher Motor - Starting Capacitors Needed?
  • Thread starter Thread starter Shawnzyoo
    Motor
An old dishwasher motor requires a manual twist to start, suggesting it may need a starting capacitor for proper function. However, many users note that dishwashers typically do not use capacitors due to their small size and design. It's recommended to check if the motor has starting windings that disengage once running, which could explain its roadside abandonment. Suggestions include contacting the manufacturer for guidance, searching for the specific part number, or seeking schematics from Wilmar. Lubrication might also help improve the motor's performance.
Shawnzyoo
I found an old dishwasher on the side of the road one night, and naturally i jumped out and scrapped it for parts.
The big motor that sits on the bottom works
My question is for the motor to turn i have to give it a twist to get going and then it turns fine.
I think I need to put on some sort of starting capacitors to give it a kick right?
thanks
Some motors have starting windings that get switch out of the circuit once running. Not sure if yours works that way. If so, that might be the reason it was on the side of the road.
From all the dishwashers I've repaired, in all that time I can't remember one ever having a capacitor. The things are so small, I don't think they're needed.
You could
1) try and contact the place that made the dishwasher and see what they say,
2) do a search on the part number and make,
3) contact Wilmar (1.800.345.3000) to see if they can find schematics and replacement parts
4) post photos of your motor here to see if someone recognizes it...
May be some lubrication can work...
thanks
You sound like you should be on that junkyard wars show lol.
You need a starting capacitor.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
