Do Commuting Operators Always Form a Basis in QM and QFT?
wangyi
Hi, I have a question,
As it is said in QM, if two operators commute, they have so many common eigenstates that they form a basis. And the inverse is right.
Now there is the question,
if A,B,C are operators, [A,B]=0, [A,C]=0,
then is "[B,C]=0" also right?
If we simply say A and B, A and C both have common eigenstates, so B and C have common eigenstates, so [B,C]=0, it seems to be right.
But in QFT, if x,y spacelike, then [\phi(x),\phi(y)]=0,
if the above is right, then we can find a point z which is spacelike according to two non-spacelike point x,y to make any non-spacelike [\phi(x),\phi(y)]=0. It looks like a paradox.
thank you!
> If A,B,C are operators, [A,B]=0, [A,C]=0,
No, it's not right. For a counterexample in the usual QM variables, let A=x, B=y, C=p_y.
For a counterexample in the Dirac gamma matrices,
let A=\gamma^0, B=\gamma^1\gamma^2, C=\gamma^1\gamma^3.
For a counterexample in QFT, replace the gamma matrices with your favorite four anticommuting field variables.
In each of these counterexamples, A commutes with B and A commutes with C, but B and C do not commute.
Carl
No. The angular momentum operators give a counterexample: A = L^2, B = L_x, and C = L_y. Then [A,B] = [A,C] = 0. But [B,C]= [L_x, L_y] = ih L_z.
It is true, however, that [B, C] commutes with A. This can be seen from the jacobi identity
[A, [B, C]] + [B, [C, A]] + [C, [A, B]] = 0.
If A has no degeneracy in its eigenvalues, then your logic works. In the presence of degeneracy, A can arrange to share a different set of eigenstates with B than it shares with C.
Carl
[A,B]=0 means you can find a set of eigenstates common to A and B.
[A,C]=0 means you can find a set of eigenstates common to A and C.
That doesn't imply these two sets are the same, so it will in general not give a set of eigenstates common to B and C.
Thank you all, i see :)
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
