One Divided by Zero: What Is the Answer?
  • Thread starter Thread starter xaviertidus
    Zero
Dividing by zero is fundamentally undefined in the real number system, as it contradicts the principles of division and the axioms of a field. While some contexts, like the extended complex plane, allow for the notation x/0 to represent infinity, this does not imply that division by zero is valid or can be treated as a multiplicative inverse. The limit of 1/x as x approaches zero tends toward positive or negative infinity, but this does not equate to a defined value for 1/0. The discussion highlights the importance of understanding the context and mathematical frameworks when addressing division by zero. Ultimately, division by zero remains a concept that eludes a straightforward answer in conventional arithmetic.
xaviertidus
Is it zero, undefined, infinity, or ERR09 :)
Mathematics news on Phys.org
Think logically about division. What does division mean? How do you divide a number by another number? Think, "repeated subtraction and revision until the quantity to subtract can no longer be subtracted". Now, what happens when you try to divide a number by zero?
In what sense do you wish to divide by zero? In the real numbers, it makes no sense to divide by zero. In other situations symbols such as 1/0 are perfectly well defined (but they still don't mean you can cancel a zero off in a multiplication).
What in the world is "ERR09"? A calculator notation?
If you are talking about dividing 1 (or any other non-zero number) in the Complex number system or any of its subfields, then "1/ 0" is just an error- you don't do it. It is true that the limit of 1/x, as "x goes to infinity" (which, in the real number system, is 'code' for "gets larger without bound"), is 0. I can't think of any situation in which it would make sense to say that 1 "divided by 0" is 0.
Dividing anything by zero is undefined (see the axioms of a field). However, as HallsofIvy pointed out, the limit of something like 1/x as x approaches 0 tends to either positive or negative infinity.
I'm going to get pedantic again. Sorry.
First, a priori, the axioms of a field (at least those normally given) do not state that 0 does not have a multiplicative inverse. It is, however, easy to deduce from the axioms that one must define 0*x=0 for all x, and one cannot cancel zeroes.
But there are more things than just fields. In the extended complex plane the symbols x/0 are defined for all non-zero x (and are equal to the symbol \infty. Division by zero is still not the inverse of multiplication, though.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
