sir_manning
- 64
Hi
I'm currently doing some work in microfluidics on a microchannel device. This microchannel has a known, constant pressure drop across it and is initially filled up with fluid 1. Fluid 2 then is allowed to flow into the channel, "pushing" fluid 1 out.
What I'd like to know is how to go about finding the pressure at the interface between fluid 1 and 2. I know the volumetric flow rate Q, one of the viscosities, and the total pressure drop across the channel.
The microchannel is rectangular and leads to a solution of:
Q=\alpha \frac{1}{\mu}\frac{dp}{dx} with mu as viscosity and alpha as some geometric factor.
However, this is for a single fluid in a microchannel of constant length. In my situation, the effective length for each fluid gets larger or small as fluid 2 pushes out fluid 1. Do I need to treat the entire microchannel as one system whose density is changing (as fluid 2 replaces fluid 1), or can I cobble together two of the time-independent solutions for each fluid?
Could someone point out some resources for this type of problem? I am assuming the flow is laminar viscous and doesn't become stratified or form an annular core. Thanks!
