What Does One Form Mean in Relativity Theory?
Jomapil
Hello, everyone
I began do learn Relativity Theory. I don't understand the term " One Forms " that appear in some books. Can anyone tell me what did it mean? The translation to Portuguese doesn't any sense and the explanation of the books is not very explicative for me.
Thank you very much.
''One forms'' are a mathematical lingo for a linear function that takes a vector and returns a scalar; it's therefore a type of tensor.
1-forms are the geometric objects corresponding to the local linear behavior of functions on a manifold.
If a patch of a manifold M is described by the coordinate functions xi : M → R, then for any function f on that patch, its local linear behavior can be given a coordinate representation in terms of the coordinate 1-forms dxi thus: df = ∑(∂f/∂xi)dxi, where the numnbers ∂f/∂xi are called the components of df.
For more details I recommend these books: "Applied Differential Geometry" and "Spacetime, Geometry and Cosmology" by William Burke.
A one-form is exactly the same as what other people call "a covariant vector". :) But to understand this you need some basis in tensor analysis.
Good evening.
haushofer - I studied tensor calculus 35 years ago and I'm reading and exercising at the same time I'm learning Relativity Theory, so I understand your explanation - EVERY covariant tensor is an One-Form.
ManyNames - I think I understood your explanation - for example the operator divergence [ div(vctor) --> escalar] is an One-Forms.
dx - I'm going soon to read about manifolds - anyway I also understood your help.
Thank you everyone and a good new week.
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
