Solving Hyperbola Problem with F(-5,0) and D(5,0) | PF - PD = \pm6
  • Thread starter Thread starter threetheoreom
    Moments
The discussion centers on solving a hyperbola defined by the foci at F(-5,0) and D(5,0) with a difference of focal radii of 6. The derived equation of the hyperbola is (x^2/9) - (y^2/16) = 1, with x-intercepts at 3 and -3, and no y-intercepts. The graph's extent is analyzed, revealing that y is real only when |x| ≥ 3, indicating no graph exists between -3 and 3. The asymptotic behavior of the hyperbola is explained, showing that as |x| increases, the graph approaches the lines y = ±(4/3)x. The discussion concludes with a method for sketching the hyperbola using vertices and asymptotes.
threetheoreom
when there is enough block ... here is my problem.
a hyperbola having F(-5,0) and D(5,0) and difference of focal radii 6.
We can use |PF - PD|= 6 or PF - PF = \pm6.
I apply the distance formula ..eleminate radicals and simplify.
I get
16X^2 -9y^2=144
Divinding both sides by 144 I get
The hyperbolic equation
(x^2/9)-(y^2/16) = 1
analysing to graph ( herein lie the problems )
First determining the intercepts ..it is easy to see the intercepts on the x-axis are 3 and -3 ( verified by makeing y 0 in the above equ.) and that making x 0 we can aslo varify that there arn't any y intercepts (-y^2/16)
( that I understand)
The book goes on to say to determine the extent of the graph
making for y we get y=\pm4/3 [square root] of x^2 -9 and
x = \pm 3/4 [squre root] of y^2 + 16
y is real if and only if |x| >= 3 thus no part of the graph lies between -3 and 3 ... in the second x is real for all y variables \Leftarrow someone explain that please.
this part is killing me, they said notice that y = \pm4/3 [square root] x^2 - 9 = \pm4/3x [square root] 1-9/x^2 . \Leftarrow I don't get this I'm thinking they factored it and i should be able to see that of course i tried ..but i can't see how . [ block]:confused:
they the go on to say that as the absolute value of x gets larger the square root of 1- 9/x^2 get closer to 1 and therefore |x| gets larger the graphapproaches the lines y \approx\pm 4/3x. thus as
|x| becomes larger the graph approaches the lines y= 4/3x and -3/4x.
Thanks guys
Orson
p.s sorry for the bad tex
Mathematics news on Phys.org
I get
16X^2 -9y^2=144
Solve for x: Adding y^2/16 to both sides, x^2/9= 1+ y^2/16= (1/16)(16+ y^2). Now multiply both sides by 9 to get x^2= (9/16)(16+ y^2). Finally, take the square root of both sides: x= \pm (3/4)\sqrt{16+ y^2}. Since a square is never negative, 16+ y^2 is never less than 16 and so \sqrt{16+ y^2} is never less than 4. Then x cannot be between -(3/4)(4)= -3 and (3/4)(4)= 3.
No factoring involved. Solve for y, just as we solved for x above. Adding y^2/16 to both sides and subtracting 1 from both sides, we get y^2/16= x^2/9- 1= (1/9)(x^2- 9). Multiply both sides of the equation by 16 to get y^2= (16/9)(x^2- 9). Now take the square root of both sides to get y= \pm (4/3)\sqrt{x^2- 9}. Finally, factor that "x2" out of the square root. (x^2- 9)= x^2(1- 9/x^2) and \sqrt{x^2}= \pm x. We have y= \pm (4/3)x\sqrt{1- 9/x^2}.
No need to be grumpy! Yes, for very large x, 9/x^2 will be very close to 9 (and getting closer as x gets larger) so \sqrt{1- 9/x^2} will be very close to 1 (and getting closer as x gets larger and larger). That means that y= \pm (4/3)x\sqrt{1- 9/x^2} will be very close to y= \pm (4/3)x. The two straight lines, y= (4/3)x and y= (-4/3)x are the "asymptotes" of this hyperbola- the hyperbola gets closer and closer to those straight lines as x gots to plus or minus infinity.
A good way of sketching this hyperbola is: Mark the vertices (-3,0) and (3,0) on the graph. Draw the rectangle with horizontal sides from (-3,4) to (3,4), (-3,-4) to (3,-4) and vertical sides from (-3,-4) to (-3, 4), (3,-4) to (3, 4). How draw the diagonals of that rectangle, extending them as far as you please outside the rectanle. Those are the asymptotes y= (4/3)x and y= (-4/3)x. Finally, starting from (3, 0), draw a smooth curve upward and to the right getting closer and closer to the asymptote y= (4/3)x. Draw a smooth curve starting at (3,0) downward and to the right getting closer and closer to the asymptote y= (-4/3)x. That give you the right half of the hyperbola. Starting from (-3,0) draw a smooth curve upward and to the left getting closer and closer to the asymptote y= (-4/3)x and a smooth curve from (-3,0) to the left and downward getting closer and closer to the asymptote y= (4/3)x. That gives you the left half of the hyperbola.
Thanks guys
Orson
Suggestion- use "itex" rather than "tex" for things you want in a line with other text. Keep "tex" for formulas on a separate line. Also, put whole formulas in tex, not just individual symbols.
Thanks hallofIvy great explanation. Yeah the computations were getting caught in the explanation n the book and in my head, that also interseting method for sketching .. i can also plug some appropriate values for x in in the equation for y.
Thanks again
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
