Onto Mappings from a Set to Its Power Set
e(ho0n3
Prove that there are no mappings from a set S onto S*, where S* is the power set of S.
The attempt at a solution
This begs proof by contradiction: Let f be a mapping from S onto S*. Then for every A in S*, there is an a in S with f(a) = A. I don't know how to proceed from here. Any tips?
Can you construct a subset of S (call it B) that is different from all of the other subsets f(a)? Hint: a is either in f(a) or not in f(a). Whichever it is, make B the opposite. Think 'Cantor diagonal'.
Hmm...let B = {a in S : a not in f(a)}. B belongs to S* and since f is onto there must be an x in S for which f(x) = B.
I guess I should now ask if x is in B? Suppose it is. Then x is not in f(x) = B. Contradiction. If x is not in B, then x is in f(x) = B. Contradiction. Hence, f can't be onto.
Thanks a lot!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
