Op-Amp Questions - V/S Output Sat. Voltage & Load Current
  • Thread starter Thread starter hemant03
    Op-amp
The discussion focuses on understanding the output saturation voltage of op-amps in relation to load current and output states. It clarifies that saturation occurs when the output stage, consisting of bipolar transistors, cannot deliver more current despite increased drive. The logarithmic scale of the graph highlights that the saturation voltage increases with load current, reflecting the inherent resistance of saturated transistors. Additionally, the saturation voltage is distinct from the actual output voltage, representing the difference between the supply rail and output terminal under saturation conditions. This explanation aims to demystify the relationship between output saturation voltage, load current, and the op-amp's operational limits.
hemant03
Hi,
I am new to circuit designing and I have a question on one of the parameters in the spec sheet of op - amp.
I don't quiet understand (see the graph) what does the output saturation voltage v/s (overdrive voltage or load current) is and why is it almost the same for outout being low or high.
I have attached the pdf of the specsheet for easy viewing.
Basically an OP-amp just multiplies the input by the gain.
You can't get a result greater than the supply voltage.
What exactly happens when your input exceeds the maximum allowed by your supply voltage depends on the internal construction of the OP-amp.
The graphs are there to show the result of doing this.
Hi,
Thanks for the response but my question is specific to the graph showing output saturation voltage v/s load current for output being high or low. Basically I am unable to understand the relation between output sat. voltage, load current and output being a high or low.
Thanks,
- Hemant
Opamps have transistors in their output stages to deliver these currents. A saturated output stage is one that cannot deliver any more current, even if you drive it harder. It is saturated !
Look at page 12 of the PDF data to see the output stage is two bipolar transistors, the PNP one for pull-up, and the NPN one for pull-down. A saturated transistor is not a zero resistance device. There will be some volts across it that will increase as the current increases.
Notice also that both axes of the data graph are logarithmic.
Thus the very nearly straight sloping part of line still indicates proportionality. ie. the apparent resistance of the fully turned on transistor is nearly constant! The increasing current simply delivers increasing saturation voltage. You should appreciate that to get this measurement, the current is being controlled by some external circuit. The transistor, being saturated, no longer has any say in limiting the current.
Yet the logarithmic scale use does exaggerate the display of voltages and currents that are very small. Thus you get to see that there is a certain minimum voltage drop across the transistor that is independent of the current, and is there even when the current drops to zero. It is, however, somewhat dependent on temperature. There are three separate curves given for different temperatures. When the current is reduced to the point the voltage drop due to bulk resistance is not significant, you get to see the remaining voltage left on the collector because of the saturated state of the base-emitter junction.
Finally - be aware that the saturation voltage is not the output voltage of the op-amp at the time. Notice there are two data graphs. One for 'output high' and the other for 'output low'. The saturation voltage is the difference between the (low or high) supply rail and the output terminal, when the opamp is driven so hard the output saturates.
I hope that does it, because I am better at using the things instead of thinking about their insides. :smile:
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
