Open air columns/ resonant length help
The discussion focuses on calculating the frequency of sound produced by a hollow tube chime that is 0.54 m long, with the speed of sound at 346 m/s. For the third resonant length, the frequency is calculated to be approximately 961.11 Hz, using the formula f3 = 3f1, which is applicable here. It is clarified that as the length of the chime decreases, the wavelength shortens, resulting in an increase in frequency. The participants confirm that the frequency of the third harmonic is indeed higher for shorter chimes, maintaining the same speed of sound. Overall, the calculations and concepts regarding resonant lengths and frequency changes are accurately discussed.
Pruzhinkin
Hollow tube chimes are made of metal and are open at each end. One chime is 0.54 m long.
A) if the speed of sound is 346 m/s, what is the frequency of sound produced by the third resonant length?
B)What would happen to the frequency of sound produced by the third resonant length if the chime were shorter?
L1 = lambda/2 or lambda = 2L
L2 = lambda
L3 = 3 * lambda/2 or lambda = 2L/ 3
f1 = v/ lambda
A) Lambda = 2L = 2 x (0.54m) = 1.08 m
f1 = v/ lambda = 346m/s / 1.08m = 320.4 Hz
L3 = 3 * (1.08m)/2 = 1.62 m
answer is
f = 346 / 1.62 = 213.6 Hz
or am i supposed to used f3=3f1, or is that only for string resonance. If it is used here then f3 = 3 * 320.4 = 961.2 Hz?
B) Not quite sure here, I understand what happens if a wavelength, frequency, or speed of sound changes, but for some reason this escapes me. I think i just fell into some sort of stupor where my head barely thinks.
Thanks in advance guys!
I think the frequency is supposed to be 320.37Hz instead of 320.4Hz. From reading into this, it appears that i do need to use f3 = 3f1 or f3=3v/2L to find the third resonant length frequency, which would give me 961.11Hz. Is this correct?
Still not sure about B)
If the frequency of the third resonant length means the frequency of the third harmonic (3 half-wavelength is there along the length of the chime), that 961 Hz is correct.
As for B: Think, what happens to the wavelength if the length of the chime decreases?
ehild
B. The wavelength shortens and the frequency increases/ temperature of course stays the same! Did i get it right?
Thanks for verifying my answer for A.:)
It is hidden but assumed that "everything the same around, just using a shorter chime". The speed of sound is the same, so you are right, frequency = speed of sound /lambda is higher for a shorter chime. ehild
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
