Open circuit voltage & EMF help
The discussion focuses on calculating open circuit voltage and current for nickel cadmium cells in series and parallel configurations. For a series connection of six 1.2V cells, the open circuit voltage is confirmed to be 7.2V, with a current of 0.72A flowing through each cell. In the parallel configuration, the open circuit voltage remains at 1.2V, with each cell supplying 0.12A. The internal resistance of a carbon cell is analyzed using the formula R(internal) = (E - V)/I, but there is confusion about which voltage to use in the calculation. Overall, participants seek clarification on these electrical concepts and calculations.
Follz20
Any help appreciated with these!
1. A battery is made up from a series combination of six 1.2 volt nickel cadmium cells supplying a 10ohm load-
a) What is the open circuit voltage?
b) Ignoring internal resistance, what is the current flowing in each cell?
2. The nickel cadmium cells in Q1 are reconnected in parallel and are connected to the same load-
a) What is open circuit voltage?
3. Determine the internal resistance of a carbon cell if the open circuit voltage is 1.70 volts and when a 10 ohm resistor is connected across the battery terminals the voltage falls to 1.26 volts.Relevant equations
I=V/R
V=IR
The attempt at a solution
1a- Do i simply use V=IR which would be 6x1.2 = 7.2 V? Is that the correct answer?
1b- Using I=V/R, is it simply 7.2/10 = 0.72A (current doesn't change through a resistor in a series circuit right?)?
2a- Do the voltages of each cell coalesce within the parallel circuit or is the total voltage simply V=IR = 1.2V?
2b- Since I(current) isn't the same through each resistor in a parallel circuit, would it be 0.12A flowing through each cell?
3- I'm really not sure how to solve for this. Transposing the E(emf)= V - IR(internal) equation, I get R(internal) = (E - V)/I. But I'm not sure which value (ie 1.26 or 1.7V) goes where or how to solve this problem.
Any help is very much appreciated! Cheers
1a) 7.2 is correct, but you don't need to use V=IR...
1b) yes and yes (you can *kind* of think about it as the current having only one route to take. There are better explanations though).
2a) yes. (ask yourself what the voltage would be if one battery where to stop working?)
2b) yes.
3) try http://en.wikipedia.org/wiki/Internal_resistance"
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
