Optical Spectrum Analyzers - Confused on Units
Optical spectrum analyzers (OSAs) can present resolution in both wavelength (nm) and frequency (Hz), which can be confusing for newcomers. The values provided by manufacturers represent measurement errors or differences in frequencies and wavelengths rather than direct conversions. Understanding that a change in frequency correlates to a change in wavelength clarifies how these units relate. By applying the speed of light in calculations, users can better grasp the relationship between the two measurements. Ultimately, comprehending these units is essential for effectively utilizing OSAs in spectral analysis.
cambridgejohn
Hi!
I am new to these, and off the bat am confused by the units.
Manufacturers quote resolution either in units of length, e.g. 0.04 nm, or HZ. For example,
0.04 pm / 5MHz
0.16 pm / 20 MHz
0.8 pm / 100 MHz.
I am thrown by this since I thought frequency was the inverse of wavelength. I get the length part and can understand when I look at a plot of Power vs. Wavelength.
I know I am overlooking something obvious...please help!
Thanks!
John
Science news on Phys.org
The numbers are not frequencies and wavelengths. The are differences between (or errors in the measurement of) in frequencies and wavelengths.
If a frequency f has wavelength \lambda, then
a frequency of f + 5 Mhz has a wavelength of approximately \lambda - 0.04pm, and so on
Thanks. The error concept part helps. I can understand when a wavelength is being measured a higher resolution helps out, and that one needs to only buy an OSA which will discern a certain wavelength spectra. And I can understand how the difference part makes sense for the wavelength.
What are the units of the proportion between the frequencies and wavelengths measured?
ok. it all makes sense now. just needed to run through some numeric examples using the speed of light to get numbers. thanks again for your help.
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
Thread 'How to model converging illumination through object plane (in ZEMAX)'
Hello community, I'm designing a projection lens system for a 35mm film projector in Zemax OpticStudio and struggling with the correct sequential mode setup for the illumination geometry. The light source is a Xenon short-arc lamp reflected by an ellipsoid mirror, which creates a converging cone with a 40.6 degree full angle that passes through the film gate. The film gate is my object plane, but the light doesn't diverge from it like a typical Lambertian source. Instead, the converging...
