Optics and Cameras: Why Does a Camera Get Wider/Longer?
  • Thread starter Thread starter poweroffive
    Cameras Optics
A camera's design becomes wider or longer primarily to accommodate larger film or sensor sizes, which allows for capturing more detail and producing larger images. The relationship between lens size and image quality is influenced by diffraction; larger lenses minimize diffraction effects, enhancing image clarity. The confusion in the discussion stems from understanding how camera dimensions relate to image size and quality. Ultimately, a larger camera setup is essential for achieving higher resolution images. This design principle underscores the importance of lens and sensor size in photography.
poweroffive
Why does a camera get wider/longer?
N/A
Well, I assume that it is to produce the largest image that can possibly be on the film. But I'm a little confused on the question as a whole? Am I on the right track and what can I add on to what I think thus far?
Thanks in advance for your help! It is totally appreciated!
It'sa little confusing, can you post the complete question?
If it is desirable to produce the large image, then why does the camera get wider/longer?
I agree, I'm not sure what the question is exactly asking! Thanks for your help thus far!
Not sure what it's asking but:
To make a large image you want a large negative, the minimum detail siaze on a film (or a CCD) is a fixed sizeso to get more detail/pixels you need bigger film (or CCD).
In a perfect camera you are limited by diffraction, the larger the lens the less the effect of diffraction
