roam
- 1,271
- 12
Here is a worked problem:
A Newton’s ring apparatus is illuminated by light with two wavelength components. One of
these wavelengths is 546 nm. If the 11th bright ring of the 546 nm fringe coincides with the
10th ring of the other wavelength, what is the second wavelength? The spherical surface
has a radius of 1 m.
Solution:
Radius of mth bright ring is:
##x = ((m-\frac{1}{2})\lambda R)^{1/2}##
So
##(10.5 \times 546 \times 10^{-9} \times 1)^{1/2} = (9.5 \times \lambda \times 1)^{1/2}##
##\lambda = 603.5 \ nm##
I don't see why they've used "m-1/2" instead of "m+1/2"?
According to my textbook the radius of mth bright fringe is:
##x = ((m+\frac{1}{2})\lambda R)^{1/2}##
Where R is the radius of curvature of the convex lens.
My textbook always uses "m+1/2" whereas my lecture notes always use "m-1/2". I'm confused because id I use the first one I get an entirely different answer.
I would appreciate it if anyone could explain why we need to use the minus for this particular problem, and not the plus.
