How to Calculate the Minimum Number of Lines to Resolve Sodium Spectrum Lines?
  • Thread starter Thread starter Arowana
To calculate the minimum number of lines required to resolve the sodium spectrum lines at 589.0 nm and 589.6 nm in the second order, first determine the resolving power using the formula R = λ/Δλ, where Δλ is the difference in wavelength. The diffraction law, a sin(θ) = m(λ + dλ), relates the order of diffraction (m) to the number of slits (N) in the grating, leading to the equation R = mN. By calculating the resolving power and dividing it by the diffraction order, the minimum number of lines can be found. Additionally, students are encouraged to demonstrate their understanding by showing their initial efforts before seeking help. For further guidance, reviewing the laboratory manual on diffraction gratings may be beneficial.
Arowana
Hi, i exam is coming up in a week and i have no clue so wat ever on how to solve this question.
How do i calculate the minimum number of lines?
What i need to answer to have full marks??
Q:
The Sodium vapor spectrum contains two bright yellow lines which have almost the same
wavelength (589.0 nm and 589.6 nm). Calculate the minimum number of lines required
in a grating which can resolve these lines in the second order.
if you have some spare time, please help me out.
You know that the resolving power is given by R = \frac{\lambda}{\Delta\lambda}. But we also have the diffraction law which states a\sin{\theta} = m(\lambda + d\lambda) so R = m N where m is the order of the diffraction and N the total number of slits in the grating. So what you want to do is to first calculate the resolving power, and then just divide by the diffraction order to obtain N :wink:
Arowana, you are supposed to show your effort before asking for help !
Pietjuh, please require that students asking for help first show what they've tried.
And to both of you, please read the posting guidelines.
THanks Pietjuh , and sorry for getting you in trouble.
Arowana, try looking at your laboratory manual Experiment 44, Diffraction Grating.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
