Optimization minimize the amount of material used.
calcula
Hi
I am having a lot of trouble with this problem. I don't actually know where to begin.
A box with a square base and open top must have a volume of 62,500 cm3. Find the dimensions of the box that minimize the amount of material used.
Need to find:
sides of base cm
height cm
Thanks
calcula said:
Hi
Need to find:
sides of base cm
height cm
Thanks
The usual place to start is to name your variables, say the height of the box and the length of the sides. Then can you write formulas for the volume of the box and area of materials used in terms of those variables?
Oh boy, I remember when I started doing maths that I had problems trying to turn words into maths
What I did was sketched the problem out along with all variables and what they represent.
Then write down your equations, how do I find volume? what restrictions does the statement 'square base and open top' place on the variables? what will give me the amount of material used?
Once you've got everything written down, then you start with your calculus
If you're anything like me, once you've got this down correctly you'll end up loving doing those elementary optimization problems!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
