Net Gravitational Force on Object #1 with Distances A and B
The discussion focuses on calculating the gravitational force on object #1 due to object #2, using the equation Fg = Gm1m2/r^2 with given distances A and B. The initial attempt involved substituting values into the formula, yielding a force calculation based on distance A. There is uncertainty regarding whether object #2 is influenced by the gravitational force of object #3 and how to factor that into the calculations. The response confirms the correctness of the initial force calculation and suggests determining the net force on object #1. Understanding the net gravitational force is essential for a complete solution.
madasrabbits
What is the magnitude of the gravitational force on object #1 as a result of object #2? Distance A = 0.383 m and distance B = 0.271 m.
the diagram for the problem is here:
http://students.physicsygoodness.com/user/1/graphics/image001.gif
Fg= Gm1m2/r^2
I tried simply plugging in the masses and using the distance for the radius.
Fg= (6.67E+-11)(10)(10)/(.383)^2
I don't know if object #2 is impacted by the gravitational force of object #3...I don't know how to incorporate that
Fg= Gm1m2/r^2
I would say that you've answered the question correctly, namely "What is the magnitude of the gravitational force on object #1 as a result of object #2?" You found \rm ||{\bf F}_{21}|| = \frac{Gm_1m_2}{r_{12}^2} .
Perhaps you should try to find the net force on object #1 now.
