Oriented angle between vectors
uwowizard
"oriented" angle between vectors
Say, we are given two vectors v1(1,2) and v2(2,1). Question - how to find an "oriented" angle in clockwise direction between the given vectors?
Note, the angle between v1 and v2 will be equal to (360-(the angle between v2 and v1))
Any suggestions will be highly appreciated. Thank you in advance.
PS: I know that one can use the dot product to find the "non-oriented" angle between vectors, but it doesn't really work in my case
Mathematics news on Phys.org
Pretend you are in 3 dimensions (append a zero z coordinate to each vector) and use the cross product.
Good idea, Stephen. Thanks.
The cross product won't give you the full answer. For example, it would give you the same "angle" for 10 degrees and 170 degrees, though they're clearly different angles.
Really, you can't do it without both the dot product and the cross product (or something like it). You need to add them both together. When you do, it makes a new kind of product called the "Clifford product" or "geometric product" -- just like when you add a real number and an imaginary number, it makes a new kind of number called a complex number.
This "Clifford product" contains the full information about how the two vectors relate, whereas its dot product and cross product "parts" each give only a piece of the puzzle. Again, this is just like with complex numbers: the real and imaginary parts give only partial information, but the real power comes when you treat the complex number as a unified entity.
Let's get specific. Write your vectors v1 and v2 in terms of an orthonormal basis, (e_x, e_y):
v_1 = x_1e_x + y_1e_y
v_2 = x_2e_x + y_2e_y
(i.e. x_1 is the x-component of vector 1, and so on.) The angle you're looking for is just the product of the vectors v_1 and v_2, as we'll see in a moment. To multiply the vectors, we first need to learn how to multiply the basis vectors they're composed of.
The rule for multiplying two of the same vector is simple: because they are orthonormal, we just get 1:
e_x e_x = 1
Multiplying two different basis vectors is where your requested orientation comes in. By "e_xe_y", we mean:
  • the plane spanned by e_x and e_y, with
  • the orientation turning e_x into e_y.
(Notice this last bit implies that e_xe_y = -e_ye_x.)
We're almost ready to calculate our angle. But first, remember that both the dot and cross products are proportional to the magnitude of the vectors. If we want to get just the angle part, we'll need to divide them both by the magnitudes. In your example, both vectors have the same magnitude: |v_1| = \sqrt{v_1 \cdot v_1} = \sqrt{2^2 + 1^2} = \sqrt{5}, and same for |v_2|.
Now, let's calculate that angle!
<br /> \begin{align}<br /> \angle(v_1,v_2) &amp;= \frac{v_1 v_2}{|v_1||v_2|} \\<br /> &amp;= \frac{(x_1e_x + y_1e_y) (x_2e_x + y_2e_y)}{\sqrt{5}\sqrt{5}} \\<br /> &amp;= (x_1x_2e_x^2 + x_1y_2e_xe_y + y_1x_2e_ye_x + y_1y_2e_y^2)/5 \\<br /> &amp;= ([x_1x_2 + y_1y_2] + [x_1y_2-x_2y_1]e_xe_y)/5<br /> \end{align}<br />
Notice the first term in square brackets looks just like the dot product, so it must be telling us \cos\theta. Similarly, the second term looks just like the cross product, so it's telling us \sin\theta. Plug in your values to get:
<br /> \begin{align}<br /> \cos\theta &amp;= \frac{4}{5} \\<br /> \sin\theta &amp;= - \frac{3}{5}<br /> \end{align}<br />
Solve these equations to get your oriented angle. Try it out for a few examples! (Notice that the orientation is given in terms of e_xe_y. In other words, positive angles mean you're turning in the same direction that turns e_x to e_y.)
I hope you find this helpful!
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
