Optimizing Automobile Suspension: Calculating Spring and Damping Constants
  • Thread starter Thread starter cd80187
    Oscillation
The discussion focuses on calculating the spring constant and damping constant for a 1700 kg automobile's suspension system. Participants identify that the spring constant can be derived using Hooke's Law, while the damping constant requires understanding of oscillation equations. The key equations mentioned include the relationship between angular frequency and the spring and damping constants, as well as the displacement equation that incorporates damping effects. A participant suggests using the decrease in amplitude over time to estimate the damping constant. The conversation emphasizes the importance of correctly applying these equations to solve the problem effectively.
cd80187
The suspension system of a 1700 kg automobile "sags" 13 cm when the chassis is placed on it. Also, the oscillation amplitude decreases by 43% each cycle. Estimate the values of (a) the spring constant k and (b) the damping constant b for the spring and shock absorber system of one wheel, assuming each wheel supports 425 kg.
I have looked at this problem for awhile, and I have no clue where to even start... So I was just looking for a little help to get started in the right place, thank you in advance
HINT: Hooke's Law
Alright, I have the same question. After applying Hooke's Law I think i found the spring constant, which is fairly straightforward. Now, how do i find the damping constant? I'm a little unclear as to which equation to use, because they have more then one unknown variable.
I was able to solve the first part, but I could not get the second part. The book gives us two equations, and I think I am supposed to use this one : omega (w) = Square root of (k/m - b squared/4msquared). But beyond that, I am unsure what I am supposed to do
I think that the following equation may be more useful.
x(t)=x_m\cdot e^{-bt/2m}\cos(\omega\cdot t)
where x is the displacement, xm is the amplitude, and I'm sure you know the rest...
Now, from the above equation we can see that at t = 0 x=x_m, yes? If we then assume that b<<\sqrt{km}, then the period of the springs is approximately that of an undamped mass-spring system, therefore we can calculate the time period of the oscillator. And you know that after one time period that xm has decrease by 43%. Can you go from here?
