B Oscillations in a driven spring
In a driven spring system, when the driving frequency (fdrive) is close to the resonance frequency (fres), the spring oscillates primarily at fdrive, but the interaction can create a modulation effect. This occurs due to resonance, where the spring's natural tendency to oscillate at fres can lead to variations in amplitude, especially if fdrive is slightly different from fres. The amplitude of oscillation increases significantly when fdrive approaches fres, resulting in a large steady-state amplitude due to resonance. Internal friction and other factors will eventually dampen these oscillations over time. Understanding these dynamics is crucial for analyzing driven oscillatory systems.
entropy1
If I have a spring with resonance frequency fres and I drive it with frequency fdrive, the spring will oscillate in a superposition of two frequencies, right?
Which frequencies are they?
Mathematics news on Phys.org
If you keep driving it with the same amplitude it will oscillate with fdrive.
Will the spring's oscillation vary in amplitude (if de driver amplitude is constant)?
Why would you expect any variation?
I think because of the resonance; the spring tends toward it. For instance: if fdrive=fres+d with d a small number, the spring's resonance frequency will interfere with the driver's frequency and produce a slow oscillation fres-fdrive I suspect. I recall having seen this at high school but I'm not sure. It is like the spring's phase aligning with the driver's phase and then run out of phase and run back in it again. Is this correct?
That would be a modulation I guess.
Motion at the natural frequency is associated with the homogeneous solution of the ODE. Even if it is not included in the mathematical formulation, in reality it will die away due to internal friction and also windage.
The steady solution is due solely to the excitation and will occur at the excitation frequency only. If the excitation is close to the natural frequency, the amplitude of the steady state solution will be quite large. This is what is known as resonance.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
