Why Is My Oscilloscope Signal Pulsating?
  • Thread starter Thread starter nordmoon
    Signal
The discussion revolves around a user experiencing pulsating signals on their oscilloscope while measuring with a pulsed laser. The signal, previously stable, began to show fluctuations in its baseline, potentially due to nearby disturbances. Suggestions include checking the photodiode and amplifier, as well as considering interference from nearby radio transmitters. The user noted that removing averaging revealed a detectable signal at intervals. The issue appears to be linked to external interference affecting the oscilloscope readings.
nordmoon
Hi, so i am doing measurements with a pulsed laser using an oscilliscope.
The signal has been ok (stable) until this afternoon when I noticed the signal started pulsating. The baseline of the signal suddenly jumps up and the baseline becomes larger, and then go down to normal.. and it keeps "pulsating" like this. Any idea what could be wrong? There might be some disturbances from other work nearby, but I am unsure what it could be.
Could you use the UPLOAD button to post pictures of your setup and show us your schematic?
One thing to check would be the photodiode/amplifier. If you have a replacement, try testing with a different one.
It looks like interference from a nearby radio transmitter going on and off, such as a paging transmitter.
I agree, when i removed the averaging I could see that there was a signal detected at some interval by the LPD3 tube.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
