Can We Visualize Exoplanetary Systems and Understand Binary Decay Rates?
In summary, there is evidence of other planetary systems being found and while there are no actual images, irregularities in the motion of stars suggest the presence of orbiting bodies. There are no close systems, but NASA has a project in the works to potentially find an isolated object similar in mass to Jupiter. There have also been over 110 extrasolar planets discovered, all of which are quite massive. The existence of wandering planets and isolated objects with Jovian+ masses is also theorized.
keeganisafish
Are there any pictures of other planetary systems? Are there any close ones? I think I heard a while back of antoher system with planets..
Astronomy news on Phys.org
To the best of my knowledge there has been evidence of other planetary systems found. None are close enough to get actual images, generally the only evidence is irregularities in motion of a star which can only accounted for by orbiting bodies. None are very close.
This site is pretty comprehensive:
http://www.obspm.fr/encycl/encycl.html
No images of exosolar planets yet, though a number of brown dwarfs have been seen (brown dwarfs are not much more massive than the heaviest planets found to date), and it seems only a matter of a few years before an isolated object (not in orbit around a star) with a mass approx the same as that of Jupiter is found.
Theer are no images yet, but NASA has a project for a http://planetquest.jpl.nasa.gov/news/lbti_update.html already in the works.
I think we're upwards of 110 extrasolar planets discovered...all massive Saturn/Jupiter sized ones (due to limitations of the detection method). I'm looking forward to the program LURCH mentioned.
cooool. Thanks.
NASA TPF website
Terrestrial Planet Finder
http://planetquest.jpl.nasa.gov/TPF/tpf_index.html
Its not getting a whole lot of press (maybe when its about time to launch it) but it may be the most important project NASA has ever done.
edit: didn't realize how far away (2012-2015) the final phase is.
I have a question. What about Planet X that scientists bragged over a while ago -l- was that just a publicity stunt to get our attention?
Good question ... loooong answer
This tale would take many an hour to tell ... just one person's very short summary:
- following the success in finding Neptune through obsersations of Uranus and much celestial mechanics (without computers! think log tables - anyone remember them?), the hunt was on for further planets
- Pluto was found later, not as big as expected, not really where it was expected, ... but then 'expected' depends on the input assumptions of your model
- some data (on long period comets, IIRC) suggested that there might be yet another planet, further out than Pluto, and possibly quite massive; got given the moniker "Planet X"
- not to be too cynical, given the public fascination with planets etc (waxed and waned over the years), sometimes an astronomer (more often a 'self-styled astronomer') got into the news with a story about Planet X; who's to say how often this was 'publicity-seeking push' vs 'thirst for news pull'?
Since the initial discoveries of Edgeworth-Kuiper Belt objects (Jewitt and Luu? 1992?), it's become increasingly clear that there isn't really a Planet X.
A good site (Jewitt's), if not as up to date as one would like:
http://www.ifa.hawaii.edu/faculty/jewitt/kb.html
Aside from the old case Nereid mentioned, did you mean this?
http://www.badastronomy.com/bad/misc/planetx/index.html
Last I heard about the planet X thing they did find an object out there, but scientists said that it was too small for a planet, so they decided to call it an astroid. Pluto was also going to be considerded an astroid, but it had a moon so they kept it as a planet.
And about the first question, I don't know if scientists have found anything, but scientists say that mathimatically there has to be solar systems like ours.
EKB objects - some big
Many hundred Edgeworth-Kuiper Belt objects have now been found, the largest of them is nearly the size of Pluto. It's clear that Pluto-Charon is just another EKB object, and the principal reason it's still called a planet is historical nostalgia. Several binary EKB objects have been found, so Pluto-Charon is not unique in this respect either.
Have there yet been found (or even theorized) two or more mutually orbiting planetoids free of stellar gravitation?
Am not quite sure what you're asking here, so the following may miss the mark:
-> wandering planets certainly exist. These are objects which formed as part of a 'solar system' (not ours) and were subsequently liberated from their parent star. Several different liberation mechanisms are likely, including ejection in the early days of the system through close encounters with other planets, ejection after the system had a close encounter with another star, and liberation as a result of the parent star going supernova
-> isolated objects with at least Jovian+ planetary masses quite likely exist. When a gas cloud collapses and fragments, some of the fragments may be small enough to condense as objects with a mass as small as that of Jupiter (or smaller). The environment in which the gas cloud fragment finds itself is important; for example, too near an OB baby, and the fragment will likely be vapourised. The cloud's composition is also likely to be important; too primordial and the cloud won't cool enough to collapse.
-> binary objects may be possible under either formation scenario above, though they may comprise only a small fraction of the total number of objects.
-> more than two objects of approximately the same mass cannot exist in a stable orbital configuration. Of course, a massive parent with many low-mass satellites is a stable configuration. Could a low-mass gas cloud end up as a Jupiter-sized parent with a retinue of 'moons'? Good question.
-> there is at least one proposed observational program that might find some of these loose Jupiters - TAOS is its name (IIRC). It will also look for other sorts of objects.
-> the various gravitational lensing surveys - OGLE, MACHO, etc - would have found isolated Jupiters (and perhaps they did), including any binaries. At least they could give (did give?) a weak upper limit to the space density of such objects, in our part of the Milky Way (and towards the LMC too?)
Nereid,
Thanks for your thorough answer. It addressed my question well.
No-one has successfully imaged an extrasolar planet yet, but we're getting closer!
http://www.roe.ac.uk/atc/news/pressrelease/20031201/index.html
Jess
more than two objects of approximately the same mass cannot exist in a stable orbital configuration. Of course, a massive parent with many low-mass satellites is a stable configuration. - Nereid
Does anyone know what the exact equation is for determining the decay rate for an equal mass, binary system?
(1/2S((GM/D2)-v2/D))-1/2=T
G=Newton's gravitational constant
M=masses of equivalent binaries
D=distance between centers of binaries
S=distance between surfaces of binaries
v=orbital velocities
T="decay rate"
Decay rate for an equal mass, binary system:
[tex]T_r = \sqrt{ 2S_d \left( g - a_r \right)^-1}[/tex]
[tex]T_r = \sqrt{ 2S_d \left( \left( \frac{G M_1}{r_1^2} \right) - \frac{v^2}{r_1} \right)^-1}[/tex]
[tex]T_r = \sqrt{ \frac{2S_d}{ \left( g - a_r \right)}}}[/tex]
[tex]T_r = \sqrt{ \frac{2S_d}{ \left( \left( \frac{G M_1}{r_1^2} \right) - \frac{v^2}{r_1} \right)}}}[/tex]
r=radius between centers of binaries
g=gravitational acceleration
a=centripetal acceleration
T=decay rate
Loren, are these factors correct?
1. What are other planetary systems?
Other planetary systems are systems of planets, moons, and other celestial bodies that orbit around a star other than our own Sun. These systems are also known as extrasolar systems or exoplanetary systems.
2. How many other planetary systems have been discovered?
As of August 2021, over 4,400 other planetary systems have been discovered. However, it is estimated that there could be billions of other planetary systems in our galaxy alone.
3. What methods are used to detect other planetary systems?
There are several methods used to detect other planetary systems, including the transit method, radial velocity method, direct imaging, and gravitational microlensing. Each method has its own strengths and limitations, and scientists often use a combination of methods to confirm the existence of a planetary system.
4. Can other planetary systems support life?
While it is possible for other planetary systems to support life, it is currently unknown if any other systems besides our own can support complex life forms. Scientists are actively searching for habitable planets within other planetary systems, but the conditions for life to exist are still being studied and understood.
5. How do other planetary systems form?
Other planetary systems are believed to form from a protoplanetary disk of gas and dust that surrounds a young star. Over time, these materials clump together and form planets. The exact process of planetary formation is still being studied and is not fully understood.
  • Astronomy and Astrophysics
