What is the Oxidation State of Ti in TiO2?
  • Thread starter Thread starter Widow
    Oxidation State
The discussion clarifies the oxidation states of titanium in TiO2 and the misconception regarding peroxides. In TiO2, the oxygen atoms have an oxidation state of -2, not -1 as in peroxides. Therefore, titanium has an oxidation state of +4 in this compound. The key takeaway is that TiO2 is titanium dioxide, not a peroxide, which resolves the confusion about the oxidation states.
Widow
Hi there! I have a quick question that could use some clarification. According to my textbook, an oxygen atom has an oxidation state of -1 when in the polyatomic ion peroxide, although it's -2 in most other cases. However, I've come across this problem where it asks for the oxidation state of Ti in the compound TiO2. I figured it was +2 since each oxygen atom carries an oxidation state of -1 (because it's a peroxide) and -1(2) is -2, so Ti must have an oxidation state of +2, right? But then when I try to ease my qualms, every single post on the Internet points toward an oxidation state of +4. I don't understand! Is this titanium peroxide or titanium dioxide? Any help would be greatly appreciated.
Chemistry news on Phys.org
Peroxides technically have the oxygens bonded to each other. TiO2 is titanium dioxide. It has a oxidation state of +4 because the two oxygens are not bonded to each other and each have an oxidation state of -2. (Two oxygens each having -2 state vs. peroxide oxygen which has O2 (-2) state)
Tina already answered your question correctly. The simplest and shortest answer is: TiO2 is not a peroxide.
Thank you so much! :)
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
