Parallel computing for PhD in Computational Astrophysics
The discussion revolves around the potential for individuals with a background in parallel computing to pursue PhD projects in Computational Astrophysics. Participants explore the necessary skill sets, the relevance of parallel computing in astrophysics compared to other fields like Computational Biology, and the challenges associated with applying these methods in astrophysical contexts.
  • Exploratory, Technical explanation, Debate/contested
  • Some participants suggest that a degree in parallel computing, combined with knowledge of partial differential equations and undergraduate physics, may provide a suitable foundation for a PhD in Computational Astrophysics.
  • Others highlight that parallel computing is increasingly significant in astrophysics, particularly in areas such as cosmological simulations and stellar evolution.
  • There is mention of the lack of established methods for solving certain equations in astrophysics using parallel computing, indicating ongoing challenges in the field.
  • Some participants express curiosity about the applications of parallel computing in Computational Biology, noting that this field may offer more funding opportunities compared to Computational Astrophysics.
  • Concerns are raised about the effectiveness of Monte Carlo methods in radiation hydrodynamics, with implications for broader astrophysical simulations.
  • One participant shares an example of an astrophysics professor using unconventional computing resources (Playstation 3s) for parallel computing, suggesting innovative approaches in the field.
  • There is a discussion about the differences in simulation approaches between biological and astrophysical systems, particularly regarding the coupling of systems and the ability to run comparative simulations.
Participants express a mix of views, with some agreeing on the potential for parallel computing backgrounds to transition into Computational Astrophysics, while others emphasize the need for strong physics foundations. The effectiveness of parallel methods in astrophysics remains a contested topic, with no consensus on their applicability across different problems.
Participants note limitations in current methodologies for applying parallel computing to astrophysical problems, particularly regarding the tightly coupled nature of astrophysical systems and the absence of a "cookbook method" for certain equations.
Individuals interested in pursuing advanced studies in Computational Astrophysics, those with backgrounds in parallel computing, and researchers exploring interdisciplinary applications of computational methods in STEM fields may find this discussion relevant.
simha
Hi,
I wanted to know if someone who has a degree in parallel computing and related work experience will be able to get a PhD project in Computational Astrophysics? What other skill sets would the person require?
I have seen many PhD positions that accept people from a parallel computing background into Computational Biology. Does the same hold good for Astronomy as well?
Thanks in advance.
Parallel computing is huge in astrophysics (more so than astronomy, per se), and becoming a bigger and bigger part of it. Essentially every large astrophysics institution has a group that works with parallel computing in cosmological, n-body, stellar evolution, markov chain monte carlo simulations, etc.
There should be many opportunities for such work, but usually institutions will lean towards people with strong physics backgrounds.
I'm curious as to the specific Computational Biology applications; do you know particular institutions and projects using parallel computing?
Maybe. If you have the ability to do partial differential equations and undergraduate physics ability, then you have the basic skill sets to do computational astrophysics. Whether you can find a program to admit you is another question.
Let me know exactly what you are interested in, and I can give you some ideas.
I think it could. If you have undergraduate physics coursework and practical HPC experience, it would make a very strong graduate school application.
Here is the basic text that will help you
https://www.amazon.com/dp/0521540623/?tag=pfamazon01-20
Parallel methods are much less used in astrophysics than in biophysics and there is a chapter in Castor that explains exactly why that is. The trouble is that do use monte carlo with radiation hydrodynamics you have to run a lot more simulations to get a convergent values, because astrophysical systems are tightly coupled. Now, if you are interested, I'd really like for you to stare at that chapter because 1) there may be a clever way of getting around that problems or 2) it *might* be possible that you just overwhelm the problem with throwing CPU. Or maybe parallel methods just won't work.
Also if you have work experience and are interested in working on astrophysics problems, then applying to astrophysics graduate schools may not be the best approach. Something that might be better is to either get a job at an HPC center or maybe apply to for a Ph.D. in high performance computing.
The other issue is that there are some fundamental things that "we do not know how to do". For example, there is not currently a "cookbook method" of solving GR equations or CFD equations with a large cluster of GPU's. There probably will be in ten years.
Hm that's interesting. Is that just relevant for radiation hydrodynamics or for the entire field too? (I'll try to get the book when I have some time). I'd expect biological systems to be more tightly coupled than astrophysical systems.
Edit: Just looked at the book - it doesn't seem to contain anything about parallel computing even in its numerical methods chapter.
Well, as one example, there was this astrophysics professor (at UMass) who made the news for using Playstation 3s for his parallel computing (since Playstation 3s are much cheaper than the alternatives).
Many thanks for everyone's replies. It was really helpful. I have had some Physics during my Engineering, plus I did an Astronomy related project during my Masters.
There are many places that do Computational Biology. The MOSAIC group at ETH, Zurich for example. I find that Computational Biology has more funding than Computational Physics or Chemistry, plus its a relatively new field. I have also seen adverts that require parallel computing for simulating brain surgery. I give a link below.
http://www.scholarshipnet.info/postgraduate/uk-msc-and-phd-studentships-in-brain-surgery-simulation-high-performance-computing/
I would probably have a better chance at doing a PhD in HPC itself, but I want to do it in an application related area. PhDs in HPC mostly seem to concentrate only on the computer science part which I do not prefer much.
Much of astrophysics boils down to radiation hydrodynamics, but the section on why monte carlo works badly in radiation hydrodynamics applies to a lot of other problems. Of course, a lot of this will change wildly over the next few years.
Sometimes. The thing that you can do in biological systems is that you can run a simulation for one organism, change things, run it for another, and then run statistics. This is hard to do with the simulations that people have traditionally done in astrophysics.
*BIG GRIN*
The cool thing about research is that you can't find the answer in the textbook. If you could, then it wouldn't be research.
So what you need to do is to read up on radiation hydrodynamics, read up on parallel computing, read up on anything that you think might be relevant, talk to people, try some things, and then write the chapter on parallel computing.
Oh okay I see. Thanks for the reply!
Ah yes, that's actually a pretty good research idea.
