Parallel resistors and ammeter problem
A student connected an ammeter in parallel with one of two identical resistors, resulting in a reading of 0.40 A. If the ammeter had been correctly connected in series with both resistors, the reading would have been 0.20 A due to the division of current between the resistors. Kirchhoff's first law indicates that the total current entering a junction equals the total current leaving it, which helps explain the current distribution. Ohm's Law is also relevant, showing that current is inversely proportional to resistance. The correct understanding of these concepts leads to the conclusion that the series connection yields a lower current reading.
Gregg
A student mistakenly connects a perfect ammeter (i.e one of negligible resistance), in parellel with one of the two of the two identical resistors. The ammeter reads of 0.40 A.
What would the reading have been if he had correctly connected the ammeter in series with two resistors? The cell also has negligible resistance.
http://upload.lhurgoyf.net/gal/Other/physics0908.JPG
\Delta Q = I\Delta T
At this stage in the book, only the two relevant equations/law have been discussed. The answer is 0.20A but I'm not exactly sure why and how I would get this answer. It seems that it can only possibly be relevant to Kirchhoff's, the sum of the currents entering a junction must equal the sum leaving the junction.
The current in between the two resistors (before the junction) must be 0.40A then, so it seems that the reading on the ammeter should be 0.40A. I don't think I understand the concept properly, a clue would be good.
Have you considered the current in the first resistor as shown in the diagram?
You're making this too complicated; as you suspected, you're not seeing the concept. You need only Ohm's Law at this point.
I=\frac{V}{R}
\therefore I \propto \frac{1}{R}
I_1 = \frac{V}{R} = 0.40
I_2 = \frac{V}{2R} = \frac{I_1}{2} = 0.20
10K
