Parametric equations questions
Curve C, defined by parametric equations x=f(t) and y=g(t), can still be considered a function of t even if it does not pass the vertical line test in the x-y plane. The vertical line test applies to traditional functions of x, while parametric equations describe a unique (x,y) pair for each t input. If f(t) represents a horizontal parabola, it can yield multiple y-values for the same x, complicating the uniqueness of solutions. Additionally, there are similarities between parametric equations and composite functions, as parametric forms can sometimes be expressed as y=f(x(t)). Understanding these concepts requires practice and intuition in working with various problems.
Dapperdub
Hi everybody, i just joined. Here's my first post
I have a few questions.
When looking at curve C and by the eye test, it doesn't pass the VLT, even though x=f (t ) and y=g (t) are functions,...then overall with curve C not passing the VLT, is it still a function since f (t) and g (t) are?
I feel like curve C is still a function because it just shows the path of the parametric equations based on coordinates that are functions. Is my understanding correct on this assumptios?
2nd question
Can parametric equations take in f (t) and g (t) as relations or will there be an error of some sort?
3rd
Is there any relation or similarites (maybe in graphs) between compositing functions vs parametric equations?
Thanks in advance!
Mathematics news on Phys.org
Hi Dapperdub, welcome to PF.
In regards to curve C, the curve plotted in the x-y plane cannot be defined simply by a "function" y= f(x). The vertical line test is to determine if y is a proper function of x. In this case they are functions of t, so if you were to plot in the x,y,t plane, you should see a unique (x,y) value for each distinct t input, so C is a function of t.
I am not sure how to address your second and third questions. Can you provide a little more detail about an application or example you are considering?
Likes Dapperdub
Wow!...perfect answer for my 1st question! I figured it so and when you brought up the x, y, t plane it made it all the more clearer! Thank you!
As for clarity on my second question…let’s see if I can rephrase it.
Let’s say f(t) is an equation of a horizontal parabola and g(t) is some function …what happens in terms of its parametric graph? Does it produce two paths in curve C since there are 2 y values for the same x from the horizontal parabola f(t)?
And for question 3
Im just wondering …..It just seems like parametric equations is similar to compositing functions (i.e. f(g(x))). Are there any similarities or correlations of the 2 concepts at all?
So, you are looking at f(t) which is not a function, such as f(t) = t and -t, this is not a parabola, but for simplicity's sake it gives the same effect of having two outputs.
and if x=f(t), y = g(t) were your parametrization scheme, then yes, you would have two outputs for each t.
You will generally not see this, since it makes it very difficult to find a unique solution. In these cases, you would separate f(t) into f_+ and f_- and solve each one individually.
For the third point, yes. When possible, thinking of parametric equations as composed functions is helpful.
You might have a parametrized curve C with points x(t) and y(t), but there might be a function y = f(x). In which case y(t) can be written as f(x(t)).
There are times when these different perspectives are more useful than others, and the best advice I have seen given is to work a lot of problems and gain some intuition.
Likes Dapperdub
You're right some information is useful than others, but yet it still bothered me. I just want to make sure I understand as much angles as i possibly can about the concept of parametric.
Thank you for your insight! I can rest for a bit until the next question arises...
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
