Partial Fraction Decomposition Problem
ko_kidd
\frac{7}{3s^{2}(3s+1)}
Can this be decomposed, and how?
I'd say, yes; it can be decomposed; without my first relearning the method and trying to decompose to partial fractions. Your denominators might be \[<br /> 3s^2 <br /> \]<br /> and \[<br /> 3s + 1<br /> \]<br />
Yep. I understood that much, but I'm confused about what I can do from there because I end up with:
\frac{A}{3s^{2}} + \frac{B}{3s+1}
which would equal out to
\frac{A}{3s^{2}} + \frac{B}{3s+1} = \frac{7}{3s^{2}(3s+1)}
then
7 = A(3s+1) + 3Bs^{2}
--which is where I'm stuck, because eliminating "s" leaves me with A = 7, which doesn't make sense if I want to separate the fraction.
It is important to remember that if one of the factors are squared, then you need to fractions for that expression, i.e. for (7/3)//(s^2(3s+1)), you need to decompose it into a/s AND b/s^2, in addition to c/(3s+1).
\frac{7}{3s^{2}(3s+1)}=\frac{As+B}{3s^{2}}+\frac{C}{3s+1}
A=-21
B=7
C=21
You may need to fill in some missing steps, but this seemed to work:
\[<br /> \begin{array}{l}<br /> \frac{a}{{3s^2 }} + \frac{b}{{3s + 1}} = performSteps = \frac{{(3s + 1)a + 3s^2 b}}{{3s^2 (3s + 1)}} \\ <br /> fromOriginalDeno\min ator,\;0s + 7 = 3s^2 b + 3sa + a \\ <br /> Answer:\;\;a = 7\quad b = \frac{{ - 7}}{s} \\ <br /> \end{array}<br /> \]<br />
Hmm, I'll have to try to this in a second.--wow the method gao xiong did works but I don't recall seeing this in my initial searches through the textbook or online.
Nice method, thanks.
Big-T, I don't understand where the a/s would come from if the highest polynomial is 9s^3 (or the highest term is cubic) when you combine the denominator.
gao_xiong's form makes the best sense, and he obtained constants as answers. He decided that \[<br /> 3s^2 <br /> \]
is an irreducible quadratic expression and gave a suitable linear binomial expression with it.
another problem that's confusing me
I have one more problem.
Would this:\frac{87}{(x)(x^{2}+13x+38)}
simplify to something like
\frac{Ax+B}{x^{2}+13x+38} + \frac{C}{x} = \frac{87}{(x)(x^{2}+13x+38)}
well first look if \{x^{2}+13x+38} has any roots over reals so the problem could get more simplified, since you could express that to some form of (x+-a)(x+-b) where a,b are the real roots.
then it would be of the form
\frac{A}{x+-a} + \frac{B}{x+-b}+\frac{C}{x}
With that "s2", you are going to need both 1/s and 1/s2.
\frac{7}{3s^2(3s+1)}= \frac{A}{s}+ \frac{B}{s^2}+ \frac{C}{3s+1}
Multiplying through by the common denominator, 7= As(3s+1)+ B(3s+1)+ Cs^2. Taking s= 0, 7= B. Taking s= -1/3, 7= C/9 so C= 63. Finally, taking s= 1, 7= 4A+ 4B+ C= 4A+ 28+ 63. 4A= 7- 91= -84, A= -21.
I don't doubt what you're saying, but how do [you] rationalize
a 1/s and 1/s^2 from one 1/s^2. I've never seen that before.
You lost the 7 in the original numerator. The correct values are A = -3, B = 1, C = 9.
